Sandy Posted June 1, 2009 Share Posted June 1, 2009 Hello Folks, I'm going to get a set of 19's for my Zed 8.5" on the front and 9.5" on the back and I was wondering what would be the perfect offset and tyre profile for this configuration?? Thanks in advance for any advice Sandy Quote Link to comment Share on other sites More sharing options...
Sarnie Posted June 1, 2009 Share Posted June 1, 2009 245/35 275/35 +18 Quote Link to comment Share on other sites More sharing options...
Adriank Posted June 2, 2009 Share Posted June 2, 2009 As above, would be great, you could go as aggressive as +15 and still be ok without work id say... Quote Link to comment Share on other sites More sharing options...
boomer816 Posted June 2, 2009 Share Posted June 2, 2009 Is it still the same fitment for 9.5 front and 10.5 rear or would it be the next size up? Quote Link to comment Share on other sites More sharing options...
Ian Posted June 2, 2009 Share Posted June 2, 2009 Is it still the same fitment for 9.5 front and 10.5 rear or would it be the next size up? Nope, the same Quote Link to comment Share on other sites More sharing options...
boomer816 Posted June 2, 2009 Share Posted June 2, 2009 Is it still the same fitment for 9.5 front and 10.5 rear or would it be the next size up? Nope, the same Is that the size of yours then Ian? Quote Link to comment Share on other sites More sharing options...
Ian Posted June 2, 2009 Share Posted June 2, 2009 Is it still the same fitment for 9.5 front and 10.5 rear or would it be the next size up? Nope, the same Is that the size of yours then Ian? Yup Quote Link to comment Share on other sites More sharing options...
Sandy Posted June 2, 2009 Author Share Posted June 2, 2009 Cheers for the info folks PS How's the handling with 9.5 front and 10.5 back on 19's? Do you get any arch rubbing, I take it the tyre profiles are the same? Sandy Quote Link to comment Share on other sites More sharing options...
Ian Posted June 2, 2009 Share Posted June 2, 2009 Cheers for the info folks PS How's the handling with 9.5 front and 10.5 back on 19's? Do you get any arch rubbing, I take it the tyre profiles are the same? Sandy No arch rubbing & mines lowered 25mm. Handling was just as good as it was before Quote Link to comment Share on other sites More sharing options...
3FIDDYZ Posted June 2, 2009 Share Posted June 2, 2009 Cheers for the info folks PS How's the handling with 9.5 front and 10.5 back on 19's? Do you get any arch rubbing, I take it the tyre profiles are the same? Sandy No arch rubbing & mines lowered 25mm. Handling was just as good as it was before If Ians are the same offset as mine, depending on how low you go you can get arch rub and you may need to buy some aftermarket camber arms to sort the positive (or negative) camber out... Quote Link to comment Share on other sites More sharing options...
Ian Posted June 2, 2009 Share Posted June 2, 2009 Cheers for the info folks PS How's the handling with 9.5 front and 10.5 back on 19's? Do you get any arch rubbing, I take it the tyre profiles are the same? Sandy No arch rubbing & mines lowered 25mm. Handling was just as good as it was before If Ians are the same offset as mine, depending on how low you go you can get arch rub and you may need to buy some aftermarket camber arms to sort the positive (or negative) camber out... Mine are a +22 which I think is the same as yours. I still cant figure out though why yours rubs seeing as we have the same widths/offsets/tyre sizes & brand & are also lowered the same amount Quote Link to comment Share on other sites More sharing options...
Chris`I Posted June 3, 2009 Share Posted June 3, 2009 Mine are a +22 which I think is the same as yours. I still cant figure out though why yours rubs seeing as we have the same widths/offsets/tyre sizes & brand & are also lowered the same amount Different camber settings would be my guess Quote Link to comment Share on other sites More sharing options...
Sandy Posted June 3, 2009 Author Share Posted June 3, 2009 Would anybody have a list of Manufactures that supply alloys in 9.5 fronts and 10.5 rears. I’ve had a quick look and all I’m getting is 8.5 fronts and 9.5 and rears. PS I take it you can’t get Finichi Firenze alloys this wide in 19’s? cheers Sandy Quote Link to comment Share on other sites More sharing options...
Ian Posted June 3, 2009 Share Posted June 3, 2009 Mine are a +22 which I think is the same as yours. I still cant figure out though why yours rubs seeing as we have the same widths/offsets/tyre sizes & brand & are also lowered the same amount Different camber settings would be my guess I believe mark is running a lot more negative camber than me Quote Link to comment Share on other sites More sharing options...
Andy Posted June 3, 2009 Share Posted June 3, 2009 Would anybody have a list of Manufactures that supply alloys in 9.5 fronts and 10.5 rears. I’ve had a quick look and all I’m getting is 8.5 fronts and 9.5 and rears. PS I take it you can’t get Finichi Firenze alloys this wide in 19’s? cheers Sandy I supply the Finichi's and they only come in 8.5J front and 9.5J rear Quote Link to comment Share on other sites More sharing options...
Chris`I Posted June 3, 2009 Share Posted June 3, 2009 Mine are a +22 which I think is the same as yours. I still cant figure out though why yours rubs seeing as we have the same widths/offsets/tyre sizes & brand & are also lowered the same amount Different camber settings would be my guess I believe mark is running a lot more negative camber than me You're just special then Quote Link to comment Share on other sites More sharing options...
Ian Posted June 3, 2009 Share Posted June 3, 2009 Mine are a +22 which I think is the same as yours. I still cant figure out though why yours rubs seeing as we have the same widths/offsets/tyre sizes & brand & are also lowered the same amount Different camber settings would be my guess I believe mark is running a lot more negative camber than me You're just special then A lot of people say that Quote Link to comment Share on other sites More sharing options...
