dwj100uni Posted June 1, 2009 Share Posted June 1, 2009 Hi All, About 2 months ago I replaced the pads on my 350z import non brembo. I have now noticed that the discs need to be replaced so I have bought new discs. Is it a problem to use the old pads (which still have loads of life) with new discs. I know this is generally a no no, but there wasn't actually anything wrong with the old disc, (not warped or anything) just worn. Will it be OK? Thanks, David Quote Link to comment Share on other sites More sharing options...
sunset350z Posted June 1, 2009 Share Posted June 1, 2009 I think personally you will be ok. Just bed it all back in nice and gently. Quote Link to comment Share on other sites More sharing options...
dwj100uni Posted June 1, 2009 Author Share Posted June 1, 2009 Thanks, Does anyone know where a write up for a non brembo disc change is, I can't find one! Thanks, DJ Quote Link to comment Share on other sites More sharing options...
sunset350z Posted June 1, 2009 Share Posted June 1, 2009 It shouldn't be much different to the brembo set up. Remove the caliper, and there may be a retaining screw holding the disc in place. If there is make sure you have the right size screwdriver to undo it as it can be a bitch to undo and its easily rounded off. Its a very simple job as long as you have the tools. PS i have non brembo goodridge brake hoses for sale at 50 quid delivered if interested. Quote Link to comment Share on other sites More sharing options...
Trev-the-Rev Posted June 1, 2009 Share Posted June 1, 2009 As Steve has said they should be fine but make sure they are worn evenly. Any lips or ridges will need to be ground down so that the whole of the pad surface comes into contact with the new disc. Quote Link to comment Share on other sites More sharing options...
