cold tyre pressure for track ?
mick43
What's optimum tyre pressure people have found for track day antics ?
I'll just be doing one or two 15 minute sessions at Silverstone on Sunday. I'm thinking of dropping a couple of pounds all round - any recommendation from the trackers (I haven't tracked the Z before and if only one/two short sessions it's not much time to play with different settings).
Thanks.
Leave them exactly as they are, unless you really want to save tyre wear then you want to raise them by about 5psi all round. Definitely don't drop pressures, you'll kill your tyres.
+1 . If you care about your tyres, raise the pressure. Otherwise the sidewalls will start being ruined quite fast.
I go out at 35psi all round from cold with my 888's
After a few laps once the tyres are up to temperature I adjust the pressures, which usually requires me letting considerable air out (12psi) as the temps are now around 47psi.
I find driving the 888's when really hot and sticky between 33 and 35psi gives me optimum grip.
