phinnies1 Posted June 2, 2009 Author Share Posted June 2, 2009 OK I may have just answered that part of the question and raised another, I just googled the codes and it came back as follows: P1065 ECM Power Supply Heater Still have no idea what that means though!! Quote Link to comment Share on other sites More sharing options...
H5 Posted June 2, 2009 Share Posted June 2, 2009 So it could be:- P0065 Air Assisted Injector Control Range/Performance or P1065 ECM POWER SUPPLY Quote Link to comment Share on other sites More sharing options...
Ebized Posted June 2, 2009 Share Posted June 2, 2009 OK I may have just answered that part of the question and raised another, I just googled the codes and it came back as follows:P1065 ECM Power Supply Heater Still have no idea what that means though!! ZMANALEX will know - try a pm Quote Link to comment Share on other sites More sharing options...
phinnies1 Posted June 2, 2009 Author Share Posted June 2, 2009 Not that either means anything to me but all I can say is that the light only comes on when the car is warm, if I stop for petrol/stop in a shop and switch the car off for 2 or 3 minutes and restart the light appears, it never appears when cold started. Very strange but I am sure it means something to somebody. BTW somebody mentioned signing up for a meet in Bristol, is there a section dedicated to that? Quote Link to comment Share on other sites More sharing options...
H5 Posted June 2, 2009 Share Posted June 2, 2009 Yep, take a look at the forum page and you'll see a section that is Meets and Events and under that are the regional meet's geographies.... Quote Link to comment Share on other sites More sharing options...
Ian Posted June 2, 2009 Share Posted June 2, 2009 The link is in my sig If you can make it I'll have my code reader with me Quote Link to comment Share on other sites More sharing options...
phinnies1 Posted June 2, 2009 Author Share Posted June 2, 2009 The link is in my sig If you can make it I'll have my code reader with me Just posted on the thread mate, very gutted but I fly out on holiday on that day so am going to miss it. as looking forward to that too. Quote Link to comment Share on other sites More sharing options...
ZMANALEX Posted June 2, 2009 Share Posted June 2, 2009 OK I may have just answered that part of the question and raised another, I just googled the codes and it came back as follows:P1065 ECM Power Supply Heater Still have no idea what that means though!! ZMANALEX will know - try a pm Geee thanks Colin The codes that you are getting are inconclusive and I would suggest dropping into your nearest Nissan Centre and ask them to plug in there hand held code reader and pull the codes. Also ask them to give you a print out of the codes stored and archived before they delete them. Any friendly Nissan Centre should do this for you without a prior appointment or monetery charge. I am asumming that you do not have a code reader. The codes that you are pulling manually: Generic DTC defininition for 065 or 0065 is Air Assisted Injector Control Range / Performance. Nissan Specific DTC Values for 1065 is ECM Power Supply. Okay, now we have a code (1065) and a DTC Value but that is not much help as that covers a multitude of potential issues so you really require to follow my recomendation and get your fault codes read properly. Once you have them then post them up or pm me and I will talk you through the fix. Below explains what I am trying say regarding where the potential issues lie, but relax because this is not serious or expensive unless your ECU, BCM or IPDM is on its way out but this is highly unlikely as when they fail they usually fail completely. Electronic Control Modules are subsystems consisting of CPUs and assorted signal inputs and outputs dedicated to controlling a component within the vehicle. They range in complexity from an Engine Control Unit which handles the logic for managing the power-train system efficiency, to an Anti-lock Braking (ABS) Control unit that monitors vehicle speed and brake fluid, to a simple body module that controls the automatic door locks or power windows. In many cases, these modules communicate to each other through such protocols as CAN, LIN, J1850, and J1959. Hope this helps. Alex. Quote Link to comment Share on other sites More sharing options...
Ebized Posted June 2, 2009 Share Posted June 2, 2009 OK I may have just answered that part of the question and raised another, I just googled the codes and it came back as follows:P1065 ECM Power Supply Heater Still have no idea what that means though!! ZMANALEX will know - try a pm Geee thanks Colin The codes that you are getting are inconclusive and I would suggest dropping into your nearest Nissan Centre and ask them to plug in there hand held code reader and pull the codes. Also ask them to give you a print out of the codes stored and archived before they delete them. Any friendly Nissan Centre should do this for you without a prior appointment or monetery charge. I am asumming that you do not have a code reader. The codes that you are pulling manually: Generic DTC defininition for 065 or 0065 is Air Assisted Injector Control Range / Performance. Nissan Specific DTC Values for 1065 is ECM Power Supply. Okay, now we have a code (1065) and a DTC Value but that is not much help as that covers a multitude of potential issues so you really require to follow my recomendation and get your fault codes read properly. Once you have them then post them up or pm me and I will talk you through the fix. Below explains what I am trying say regarding where the potential issues lie, but relax because this is not serious or expensive unless your ECU, BCM or IPDM is on its way out but this is highly unlikely as when they fail they usually fail completely. Electronic Control Modules are subsystems consisting of CPUs and assorted signal inputs and outputs dedicated to controlling a component within the vehicle. They range in complexity from an Engine Control Unit which handles the logic for managing the power-train system efficiency, to an Anti-lock Braking (ABS) Control unit that monitors vehicle speed and brake fluid, to a simple body module that controls the automatic door locks or power windows. In many cases, these modules communicate to each other through such protocols as CAN, LIN, J1850, and J1959. Hope this helps. Alex. Having dropped that one on you Alex I'll see you right at the bar on the Hoon in September - but top man for the answer, most of which goes way over my head but if that don't help phinnies1 out nothing will! Quote Link to comment Share on other sites More sharing options...
H5 Posted June 2, 2009 Share Posted June 2, 2009 I woulda typed that ^^^^^^^ if I'd had the time. Or knew WTF any of it meant! Nice one Alex. Quote Link to comment Share on other sites More sharing options...
phinnies1 Posted June 2, 2009 Author Share Posted June 2, 2009 Thanks so much for your help guys, especially Alex, its great to find a place like this. Will pop down to dealership tomorrow although from my experience (having had Nissans for the last 9 years) they are not that friendly ! Quote Link to comment Share on other sites More sharing options...
choptop Posted June 3, 2009 Share Posted June 3, 2009 Thanks so much for your help guys, especially Alex, its great to find a place like this.Will pop down to dealership tomorrow although from my experience (having had Nissans for the last 9 years) they are not that friendly ! Just sent you PM Quote Link to comment Share on other sites More sharing options...
boOsted=Z Posted June 11, 2009 Share Posted June 11, 2009 welcome Quote Link to comment Share on other sites More sharing options...
phinnies1 Posted June 16, 2009 Author Share Posted June 16, 2009 Thanks for all of your help guys, problem has been sorted, took a while to diagnose it but the cause of the problem was a wire (again I dont profess to understand the problem but apparently there is a memory wire which goes from the diagnosis plug to the ECU which had been somehow disconnected.) A very small but quite costly problem but at least its sorted and all is good. Did 500 miles over the weekend to Download festival via Reading and she drove like a dream. Quote Link to comment Share on other sites More sharing options...
Ebized Posted June 16, 2009 Share Posted June 16, 2009 Glad you got it sorted Quote Link to comment Share on other sites More sharing options...
