Jay Posted May 27, 2009 Share Posted May 27, 2009 Ok guys this is a very simple thing to do. Open up the door and you will see two rubbel seals, pull them off and you will see this: Ok so this is the passenger door so you just remove the bolts with a 10ml socket, However be careful on the bottom bolt it can be a pain to get to and the bolt likes to jump loose lol, so u may want to get a magnetic star screwdriver Ok so once the bolts are free its a simple job of just lifting the door handles slight and just wiggle it gently till it comes loose. So thats you guys job done. Very simple just be careful when removing the door handle as it is quite fragile. After you have removed the handle the zed will look like this lol Hope this helps guys and gals Quote Link to comment Share on other sites More sharing options...
ARphotographs Posted May 27, 2009 Share Posted May 27, 2009 your meant to be studying you git! otherwise come out and play in the tunnels! Quote Link to comment Share on other sites More sharing options...
Stew Posted May 27, 2009 Share Posted May 27, 2009 Top Stuff Jay. Thanks for taking the time to do that. Quote Link to comment Share on other sites More sharing options...
rtbiscuit Posted May 27, 2009 Share Posted May 27, 2009 is that a glimpse of your new black handles there. Quote Link to comment Share on other sites More sharing options...
Jay Posted May 27, 2009 Author Share Posted May 27, 2009 It may well be lol Quote Link to comment Share on other sites More sharing options...
rtbiscuit Posted May 27, 2009 Share Posted May 27, 2009 It may well be lol so whens the big unveiling then oh; and go and do some bloody revision you probably only have like a week maybe 2 left before the hols start. Quote Link to comment Share on other sites More sharing options...
3FIDDYZ Posted June 4, 2009 Share Posted June 4, 2009 So where is the guide for refitting them!!!!! Drivers door is a pain in the hole!! Anyone with any ideas? Quote Link to comment Share on other sites More sharing options...
Cragus Posted June 4, 2009 Share Posted June 4, 2009 Good job Jay! Quote Link to comment Share on other sites More sharing options...
3FIDDYZ Posted June 4, 2009 Share Posted June 4, 2009 Dont worry!!! Done it.... Drivers side is a pain to refit... But can be done, didnt do a how too, but if anyone has a problem refitting in the future shout! Quote Link to comment Share on other sites More sharing options...
Jay Posted June 4, 2009 Author Share Posted June 4, 2009 Its the same process 3fiddy, peice of p*** Quote Link to comment Share on other sites More sharing options...
3FIDDYZ Posted June 4, 2009 Share Posted June 4, 2009 Its the same process 3fiddy, peice of p*** Not on the drivers its not.... You have the issue with the "lock" arm.... Quote Link to comment Share on other sites More sharing options...
M350ZB Posted June 5, 2009 Share Posted June 5, 2009 Nice write up Quote Link to comment Share on other sites More sharing options...
stanski Posted June 5, 2009 Share Posted June 5, 2009 Nice one Jay - handy to know - this is the kind of easy photo step by step guide that simpletons like me love But get a decent camera or stop using your phone - he he he he ! Quote Link to comment Share on other sites More sharing options...
M350ZB Posted June 5, 2009 Share Posted June 5, 2009 But get a decent camera or stop using your phone - he he he he ! :lol: Quote Link to comment Share on other sites More sharing options...
rtbiscuit Posted April 25, 2010 Share Posted April 25, 2010 did this yesterday, might be worth noting that the drivers side has 2 bolts in the bottom section unlike the passenger side which only has one. the second bolt on the bottom of the drivers side is an arse to get to and an even bigger arse to put back in. i found in the end the best way was to put the original 2 back in but leave them slightly loose, that way you can move the handle about to get the last one in. also when refitting, there is a long arm on each handle, you'll see it when its off, when re fitting the end of this needs to go in to a little blue holder inside the door. pre warning its not easy to see, a torch will help. if you don't slot the bar into this hole the handle will still go on, but if you shut the door and try to open it, the handle will move like normal, but its not actually attached to the door mechanism so the door won't open. so don't do both at the same time or you'll lock yourself out of the car, or leave the windows wound down as you can then open it with the internal handle Quote Link to comment Share on other sites More sharing options...
