MAD7BOY Posted May 26, 2009 Share Posted May 26, 2009 Hi, I have an Evo 8 in which I have fitted a mini digital dashboard intended for a bike. It has an RPM graph and dual stage shift lights. It was intended to pick up the RPM signal by induction from the HT leads but this signal is unreliable on the coil packs of my Evo. So I'm looking to be able to convert the RPM signal on the RPM wire of the ECU into a pulsed signal which my digi dash can use. Anyone got any clues on how to do this? Is there a product that does this or will I need a custom circuit or what? Does anyone have any info on what format the signal will be in from the ECU? All help apprieciated. Cheers. Quote Link to comment Share on other sites More sharing options...
Chris`I Posted May 26, 2009 Share Posted May 26, 2009 I assume you've asked on the MLR Ben? I members are quite knowledgable so will probably have some good ideas. Just prepare for the stupid ones too! Adam@Z1 has a good working knowledge of a lot of cars so you could PM him Oh and moved. Although a technical topic, its not about a 350z Quote Link to comment Share on other sites More sharing options...
