new2350z Posted May 25, 2009 Share Posted May 25, 2009 After months of looking I finally bought my zed and am totally chuffed with it . I've a question over which fuel to run it on for 'normal' everyday use. I know the manual says to use 98ron - obviously its probably best to put in the best quality super unleaded you can but my problem is only a few garages near me do superunleaded which is only 97ron and I've already got caught out and had to put in standard 95ron unleaded on one visit. I just want to know if its ok to run the car on standard 95 ron unleaded for normal use - I've heard that you may have some performance loss but will not cause any actual engine damage since most newer cars engine management adjust firing to prevent the knocking, is this true? Also have read that using standard 95ron with an octane booster additive is good too. Anyone any advice for best ways to run the zed for normal day to day use. Basically I'd like to keep fuel cost down but not at the expense of any possible engine damage since the car I got has good low mileage. If was doing a track day or fast run I'd obviously want to be using the highest ron super unleaded. Cheers Quote Link to comment Share on other sites More sharing options...
Maccaman Posted May 25, 2009 Share Posted May 25, 2009 The car will run ok on 95 ron, I ran mine on that until I found out it should be higher If you use 97/98 ron you will get better mpg which will off-set some, if not all, the difference in price. Obviously it's also better for the engine so go for the higher whenever you can. Quote Link to comment Share on other sites More sharing options...
martinmac Posted May 26, 2009 Share Posted May 26, 2009 As Keith says it will run fine on 95 if you get stuck. Best to use all the 95 up before putting in the higher ron if you can. Quote Link to comment Share on other sites More sharing options...
Chris`I Posted May 26, 2009 Share Posted May 26, 2009 +1 on what the others said. Fine to run on 95RON, but if you can get 98RON or better the car will be happier, as I find I get better MPG which offsets the extra cost of the better stuff Quote Link to comment Share on other sites More sharing options...
Toon Chris Posted May 26, 2009 Share Posted May 26, 2009 +1 on what the others said. Fine to run on 95RON, but if you can get 98RON or better the car will be happier, as I find I get better MPG which offsets the extra cost of the better stuff +1 Quote Link to comment Share on other sites More sharing options...
H5 Posted May 26, 2009 Share Posted May 26, 2009 +1 on what the others said. Fine to run on 95RON, but if you can get 98RON or better the car will be happier, as I find I get better MPG which offsets the extra cost of the better stuff +1 +2 Quote Link to comment Share on other sites More sharing options...
Stew Posted May 26, 2009 Share Posted May 26, 2009 Looks like we all agree. No harm runing with 95 but if better stuff is available then might be worth taking. Quote Link to comment Share on other sites More sharing options...
new2350z Posted May 26, 2009 Author Share Posted May 26, 2009 Thanks for the replies guys - looks like its unanimous to go with the best available. Taken on board... Cheers Quote Link to comment Share on other sites More sharing options...
BulletMagnet Posted May 26, 2009 Share Posted May 26, 2009 I'm glad I got a few V-Power stations in my town. Quote Link to comment Share on other sites More sharing options...
ddmroadster350z Posted May 26, 2009 Share Posted May 26, 2009 I don't push my Z on hence used 95ron with the odd 98 for about a year with NO problems, but for the last 18months have used Shell V power & the extra mpg in some cases 3mpg plus the extra power on tap far outweighs the extra 7ppg. DDM Quote Link to comment Share on other sites More sharing options...
ddmroadster350z Posted May 26, 2009 Share Posted May 26, 2009 Sorry meant 7pence per litre. Enjoy what performance the car has,by what you can afford DDM Quote Link to comment Share on other sites More sharing options...
