Carbon fibre vinyl?
jim
I've got some I can send you a strip which should allow you to have lots of practice. Call it £1.50 on the paypal towards vinyl and postage. It will be a length 10 cm wide by about 60 cm long. As it's easier to just cut a strip than a little box. Pm me if you want it.I'm away at the moment but will be back tonight and can sort it then.
Many thanks. I'll PM you later today. :thumbs:
Here's my first attempt. It's not easy, but now I know the difficult areas I might have another go and see if I can make the next one a bit tidier.
Thanks to rtbiscuit for the vinyl.
i bet if you have a look at the badge you should be able to see that the Zed is possibly on 2 pins with a bit of glue on the back, you should be able to scrape it away and take the zed off. then lay your vinyl and then glue the zed back on.
i don't know for certain if the zed comes off, but most of the other badges come in sections.
Never thought of that - will have a look at it later. It would certainly help to make a much neater job.
actually i get that looks quite good
It would have if I was better at applying the vinyl & if I hadn'tmade the mistake of cutting out a section so I could see the logo & then deciding it looked crap so had to cover a square section of it :lol:
I've had a look, but I don't think it is that easy. See the photo below.
