chippy Posted May 21, 2009 Share Posted May 21, 2009 Hi guys I've had my 05 Z for about a month now and it's done just over 10k miles. I've noticed that it has the clicky drivers side CV joint issue and I'm going to give the garage a ring about it tommorrow as they gave me a 12 month warranty on it. The problem, is that I'm off to France on the 4th June for a week with the car and will probably be racking up quite a few miles. Is it safe enough to keep using and have the joint problem sorted when i get back? cheers Quote Link to comment Share on other sites More sharing options...
AK350Z Posted May 21, 2009 Share Posted May 21, 2009 It should be fine, just make sure the garage get the proper repair kit and don't just re-grease it. If they have trouble, contact ZMANALEX on here. Quote Link to comment Share on other sites More sharing options...
S1 HNK Posted May 21, 2009 Share Posted May 21, 2009 nothing to worry about mate, mines been doing it for over a year now. I have been informed (phil esr) that it causes no harm at all, its just the noise that is the only problem Quote Link to comment Share on other sites More sharing options...
ZMANALEX Posted May 21, 2009 Share Posted May 21, 2009 Safe to drive mate as you will not have a failure if it is a clicky axle issue but the noise is very annoying. Check out my link below. viewtopic.php?f=32&t=21842 Cheers, Alex. Quote Link to comment Share on other sites More sharing options...
