H5 Posted May 17, 2009 Share Posted May 17, 2009 As the title says, it's not dropping or working at all now. It had been intermittent for 6 or 7 times but now it won't budge. When I try the switches I get the solenoid clicking (I assume) but no movement..... Quote Link to comment Share on other sites More sharing options...
IanS16 Posted May 17, 2009 Share Posted May 17, 2009 Rob, Think there is a reset button under the door panel on the actual window motor. Failing that could water have gotten into the switch if you had windows open today? Quote Link to comment Share on other sites More sharing options...
H5 Posted May 17, 2009 Author Share Posted May 17, 2009 Handy to know, will have to get the door card off later this week. The window wasn't open much, Becca was sat by it! Quote Link to comment Share on other sites More sharing options...
IanS16 Posted May 17, 2009 Share Posted May 17, 2009 Found it: http://www.350z-tech.com/zwiki/Service: ... _Procedure Quote Link to comment Share on other sites More sharing options...
H5 Posted May 17, 2009 Author Share Posted May 17, 2009 Top man, thanks, will try it. Quote Link to comment Share on other sites More sharing options...
sl114 Posted May 17, 2009 Share Posted May 17, 2009 Maybe its dirty? Quote Link to comment Share on other sites More sharing options...
H5 Posted May 17, 2009 Author Share Posted May 17, 2009 Maybe its dirty? Quote Link to comment Share on other sites More sharing options...
sl114 Posted May 17, 2009 Share Posted May 17, 2009 Quote Link to comment Share on other sites More sharing options...
H5 Posted May 17, 2009 Author Share Posted May 17, 2009 I thought you normally came Quote Link to comment Share on other sites More sharing options...
sl114 Posted May 17, 2009 Share Posted May 17, 2009 I thought you normally came always Quote Link to comment Share on other sites More sharing options...
Adam@Z1auto.com Posted May 17, 2009 Share Posted May 17, 2009 common issue unfortunately cleaning the brushes can extend the life a bit, but best bet is replacing the motor completely. I have to do mine this week as well, as the passenger side has gotten very slow Quote Link to comment Share on other sites More sharing options...
H5 Posted May 18, 2009 Author Share Posted May 18, 2009 Thanks Adam, will see what I can get my hands on..... Quote Link to comment Share on other sites More sharing options...
