Idling and ESP problems.
Reidy
Hi members.
I am new to Z ownership but allready have some niggles.I allready have under warranty some items done .The clicking from the rear axle,new tailgate struts and drivers seat bolster and cover replaced due to excessive wear.
Can you help on my next probs.
1. After a run with the engine warm,i give the engine a minute to settle.On idle the engine gives a miss every now and again almost like a back pressure noise sounding from the drivers side footwell.Nissan says this could be unburnt fuel typical of V6.I would of thought that in this modern day it should run smooth.
2.On driving hard into a corner with ESP on , it kicks in sometimes grabbing the brakes . I am not taking risks when it is doing this.Generally one of the wheels is unloaded due to the camber . Any one experience this as its annoying and disturbing.
Thanks hope you be of help
Reidy
1. What petrol you using???
2. Normal - corrected by turning esp off :scare: :scare::scare:
Thanks for your tips.I will have a listen with the air con switched off and on to see if it makes a difference.
As regards to the petrol i feed it shell optimax i wouldnt want those little mouths to go hungary. I do drive with the ESP off when going a bit hard but was still trying to find out if it is a over sensitive system when switched on.
Reidy
