Rear Brembo pads
ireynolds
Guys ive looked and looked.
Is there a walkthrough with pictures of how to change rear brembo pads?
Ive got the car jacked up.
Pull the two pins out.
Then pulled the two bars out.
I cant get the pad itself out???
Also, does the handbrake need to be off? Im not sure how i will stop the car rolling if it is off?
Handbrake needs to be off.
Put the car in gear and chok the wheels with a brick to stop it from rolling, make sure the surface is even tho.
If you have axlestands, use them.
Hope this helps
