Rare JDM
Ian
I started to fit my Rare JDM harness cover this afternoon B)
It looks great but its not secured properly yet because I cant get the 2 front studs that the old engine cover attatched off :rant:
^^ I need to get that off on each side but it wont budge :dry:
Any ideas?
two nuts.
screw them together TIGHT then you should be able to back it out turning the bottom one. ;)
Looks good though! Think you need a few bits poilshed though! B)
Did you get a another timing cover?
By the looks of it that thread is attached to that.
It is attached to the timing cover but it is removable
two nuts.
i really need to give the engine bay a good clean, theres a few more polished bits to go in eventually though ;)
Ian - it's not installed correctly
the front L bracket gets secured on the inside of the cover, not the outside
to remove the studs, take a 10mm nut, tighten it down on the stud, then remove it..it should unthread the stud ;)
:thumbs:
Will try it later :blush:
