rtbiscuit Posted May 4, 2009 Share Posted May 4, 2009 This may sould silly but i can't get mine to stick on. i bought some carbon fibre covers from M350ZB, nothing wrong with them product is fine, what i need help with is how to attatch them. i've just tried no more nails super strong doublesided adhesion tape. it sticks fine to the CF but just won't grip to the original plastic covers. and this stuff is far more sticky than your average 3M tape. so what have other people used? should i just go and order some Tiger seal adhesive and make them permenant? and bond them on so they never come off? Quote Link to comment Share on other sites More sharing options...
clarkie34 Posted May 4, 2009 Share Posted May 4, 2009 Got mine of ESR,they was supplied with 3m tape.Found no problems with them. Quote Link to comment Share on other sites More sharing options...
martinmac Posted May 4, 2009 Share Posted May 4, 2009 I had the thin 3M tape in double rows on each face and it was fine. Have you cleaned the existing cover Rich. ( I think I know the answer to that ). Quote Link to comment Share on other sites More sharing options...
rtbiscuit Posted May 4, 2009 Author Share Posted May 4, 2009 i gave them a through wipe down with a cleaning cloth. buth there seems to be a greasy residue on the surface, feels a bit like oil Quote Link to comment Share on other sites More sharing options...
clarkie34 Posted May 4, 2009 Share Posted May 4, 2009 Try alcohol say turpentine or white spirit. Quote Link to comment Share on other sites More sharing options...
Chris`I Posted May 4, 2009 Share Posted May 4, 2009 Might be worth a bit of degreaser. So long as you dont mind possibly discolouring the original finish a bit. If its nice and clean, you should have no problems with it sticking. Quote Link to comment Share on other sites More sharing options...
Stew Posted May 4, 2009 Share Posted May 4, 2009 Was going to say try cleaning the surface. Even keying it slightly would help. Quote Link to comment Share on other sites More sharing options...
rtbiscuit Posted May 4, 2009 Author Share Posted May 4, 2009 update, got one on, got the old lighter fluid out and gave it a rub down with that, pulled off all the no nails cack, used normal double sided tape, but covered the whole thing has worked a treat, am just doing the second one now. Quote Link to comment Share on other sites More sharing options...
rtbiscuit Posted May 4, 2009 Author Share Posted May 4, 2009 both have just pinged up again, have tried adding heat into the equation as well as sitting heavy objects on them and leaving them. if that doesn't work then the little fekers are going to meet my friend sicaflex tigerseal. the strongest bonding agent known to man Quote Link to comment Share on other sites More sharing options...
Muddy Posted May 4, 2009 Share Posted May 4, 2009 try hot glue Quote Link to comment Share on other sites More sharing options...
srobrien Posted May 5, 2009 Share Posted May 5, 2009 I used a glue gun on mine as the 3M tape kept unsticking, more permenant fix but i don't suppose i will be needing them removed for anything. R Quote Link to comment Share on other sites More sharing options...
M350ZB Posted May 5, 2009 Share Posted May 5, 2009 Anys pics of it fittted bud Quote Link to comment Share on other sites More sharing options...
rtbiscuit Posted May 5, 2009 Author Share Posted May 5, 2009 will borrow a glue gun from work tonight and fit them when i get home. got a cricket match tonight so will be late, but i will put up pics when they're on. Quote Link to comment Share on other sites More sharing options...
M350ZB Posted May 5, 2009 Share Posted May 5, 2009 Cool Quote Link to comment Share on other sites More sharing options...
rtbiscuit Posted May 6, 2009 Author Share Posted May 6, 2009 finally got the little feckers on. Quote Link to comment Share on other sites More sharing options...
Chris`I Posted May 6, 2009 Share Posted May 6, 2009 Quote Link to comment Share on other sites More sharing options...
srobrien Posted May 7, 2009 Share Posted May 7, 2009 lol, that looks familiar....well done to you sir! top job R Quote Link to comment Share on other sites More sharing options...
M350ZB Posted May 7, 2009 Share Posted May 7, 2009 Looking good bud Quote Link to comment Share on other sites More sharing options...
