From A to Zed Posted April 27, 2009 Share Posted April 27, 2009 Hi all, I have replaced my Bose headunit with an Alpine unit which is currently connected to the Bose AMP and speakers. I intend to bypass the Bose system completely with the following set up; Alpine headunit -> 1 Alpine V12 4 channel amp Front 2 channels -> To power a pair of 6.5" focals in the doors. I will use MDF rings and dynomat. Rear 2 channels -BRIDGED-> 10" focal sub in the factory space. I will attempt to seal / dynomat this space. The rear speakers will just be disabled. I removed the Bose sub this weekend (on a little recce) and the internal width of the hole is 9.5" - and if I have read correctly the Bose sub is 10.5." I intend to use the factory grill to keep everything stealth and was wondering how you guys have mounted your woofers in the factory space? Will a 10" fit ok or will the new woofer be slightly too small? Would you recommend making an MDF ring / spacer to mate the sub with the metal hole? Thanks for your help guys, Matt Quote Link to comment Share on other sites More sharing options...
3FIDDYZ Posted April 27, 2009 Share Posted April 27, 2009 Saw kenwood are doing a nice new 10" sub... (just on the size, my 10" JL almost falls through the hole... need to tie a scaffold plank to its ass.... sorry old joke!) its a slim line one and has good reviews... KFC-WPS1000F Quote Link to comment Share on other sites More sharing options...
From A to Zed Posted April 27, 2009 Author Share Posted April 27, 2009 That does look nice mate Ideal for the tight space too. To cut a long story short I'm using hardware I have lying about so I'm not really looking for a new sub. I'm just trying to figure out the best way to mount the sub woofer without hacking up the interior Quote Link to comment Share on other sites More sharing options...
