SAFC99 Posted April 25, 2009 Share Posted April 25, 2009 I have an annoying squeek coming from the boot, it dissapears if i open and close the boot, when the squeek is happening and i open and shut any of the doors the squeek can be heard. Anyone had this or got any ideas as i cant find whats causing it. Quote Link to comment Share on other sites More sharing options...
R35LEE Posted April 25, 2009 Share Posted April 25, 2009 The 'squeek' could be from loose hinge bolts or loose bolts on gas struts? Is it a plastic rattle and squeek or more metallic? The latch may also require attention. Have a friend outside the car push on the hatch down and from side to side while your inside. If you hear nothing its probably a trim plastic moving or you have a ghost! Hope this helps! Quote Link to comment Share on other sites More sharing options...
Gizmo-R Posted June 9, 2010 Share Posted June 9, 2010 Thread resurrection!! I have this problem I believe and it sounds like I have crickets in the boot! Very annoying and I've yet to pin down the root of the problem! If I thump the top corner of the boot on the outside you can hear it make that squek noise. Any more ideas on this one chaps? Quote Link to comment Share on other sites More sharing options...
pathfinder123 Posted June 10, 2010 Share Posted June 10, 2010 Try rotating the 2 rubber bump stops at the front edge of the boot lid. If that stops it apply some lubricant between the rubber and the metal. I used silicon grease. S. Quote Link to comment Share on other sites More sharing options...
HEADPHONES Posted June 10, 2010 Share Posted June 10, 2010 Another cause i found was the plastic trim around the tools rubbing against the spare wheel coz I didn't put things back properly Quote Link to comment Share on other sites More sharing options...
GT4 Zed Posted June 10, 2010 Share Posted June 10, 2010 Mine was from the privacy tonneau which i promptly ditched then from the tonneau divider which went too Its all quiet now except i have removed the thick carpet, all the sound deadenning underneath the car, tools and spare tyre so the K1 is multiplied by 2 Quote Link to comment Share on other sites More sharing options...
Cragus Posted June 10, 2010 Share Posted June 10, 2010 Rubber boot stumps are likely to be the culprit. Grease them bad boys and away you go.... Quote Link to comment Share on other sites More sharing options...
Gizmo-R Posted June 10, 2010 Share Posted June 10, 2010 Rubber boot stumps are likely to be the culprit. Grease them bad boys and away you go.... Is that the 2 stumps that are byt the boot lip as you open the boot? Quote Link to comment Share on other sites More sharing options...
pathfinder123 Posted June 11, 2010 Share Posted June 11, 2010 Yup... S. Quote Link to comment Share on other sites More sharing options...
