roastbeef78 Posted April 24, 2009 Share Posted April 24, 2009 Hi there, Just picked up a 53 plate 350z UK GT, any reason why the rev limiter is cutting in at 5500rpm? Cheers. Quote Link to comment Share on other sites More sharing options...
xStric9x Posted April 24, 2009 Share Posted April 24, 2009 Welcome bud Mmm thats a new one, i've not heard of that happening before. You should be hitting the limit at 6600rpm pre06, i'm sure someone will be along shortly to answer you question. Quote Link to comment Share on other sites More sharing options...
Chesterfield Posted April 24, 2009 Share Posted April 24, 2009 Another question - probably a verylog shot but this car hasn't been fitted with anything like the UTEC engine management system by the previous owner has it? You can alter the rev limit with those. Quote Link to comment Share on other sites More sharing options...
fatalus Posted April 24, 2009 Share Posted April 24, 2009 Definitely sth wrong with your ECU. Reprogrammed (really badly) maybe? Quote Link to comment Share on other sites More sharing options...
roastbeef78 Posted April 24, 2009 Author Share Posted April 24, 2009 Hi there, Jsut done some more investigation, it revs cleanly up to the proper rev limit in neutral, or under gradual acceleration, but cuts in at about 5500rpm under full hard acceleration. Any ideas? Cheers. Quote Link to comment Share on other sites More sharing options...
xStric9x Posted April 24, 2009 Share Posted April 24, 2009 Have you set the limit on the gauge to 6600rpm, it can be misleading cause when i get up that end of the rev range i'm concentrating on the road and use the rev limit light( through the corner of my eye) as an indication. Quote Link to comment Share on other sites More sharing options...
roastbeef78 Posted April 24, 2009 Author Share Posted April 24, 2009 Hi there, Jsut done some more investigation, it revs cleanly up to the proper rev limit in neutral, or under gradual acceleration, but cuts in at about 5500rpm under full hard acceleration. Any ideas? Cheers. As above, could it be drive shaft? Quote Link to comment Share on other sites More sharing options...
BulletMagnet Posted April 24, 2009 Share Posted April 24, 2009 When you first start the car, does the multidisplay show 5500rpm or 6600rpm? Mine was set at 6000rpm when I first bought mine and it was only after I fitted my grounding kit, which involved disconnecting the battery, that the rev limiter reset itself to 6600rpm (battery was disconnected for about 20mins) Hope this helps. Quote Link to comment Share on other sites More sharing options...
From A to Zed Posted April 24, 2009 Share Posted April 24, 2009 You can set the rev limit yourself (for UK cars) but I'm not sure about JDM's If you use the buttons on the left of the dash cowling you can scroll through the MPG, Temp etc until you see the rev limit. You can set the engine rev limit from there Quote Link to comment Share on other sites More sharing options...
Chesterfield Posted April 24, 2009 Share Posted April 24, 2009 Thats just the shift light that you can set using those lights, not the actual rev limiter. Quote Link to comment Share on other sites More sharing options...
From A to Zed Posted April 24, 2009 Share Posted April 24, 2009 Ah damn, I was hoping I could set it to 4k if I ever lent the car to someone Quote Link to comment Share on other sites More sharing options...
Chris`I Posted April 24, 2009 Share Posted April 24, 2009 Can I ask what tells you the rev limiter is at 5.5k? Is it the shift light or are you bouncing off it? Have you tried acutally hitting the red line? Most people get confused betwen the redline and shift light Quote Link to comment Share on other sites More sharing options...
From A to Zed Posted April 24, 2009 Share Posted April 24, 2009 Clearly I did ^^^ Quote Link to comment Share on other sites More sharing options...
roastbeef78 Posted April 24, 2009 Author Share Posted April 24, 2009 It is bouncing off the rev limiter at 5500rpm, the shift light is set to 6600rpm, as I said in neutral or slowly accelerating it will rev up to 6600rpm, it is just under hard acceleration it bounces off the limiter at 5500rpm. Quote Link to comment Share on other sites More sharing options...
fatalus Posted April 24, 2009 Share Posted April 24, 2009 Are you sure it is not the ESP that makes this cut? Quote Link to comment Share on other sites More sharing options...
Chris`I Posted April 24, 2009 Share Posted April 24, 2009 It is bouncing off the rev limiter at 5500rpm, the shift light is set to 6600rpm, as I said in neutral or slowly accelerating it will rev up to 6600rpm, it is just under hard acceleration it bounces off the limiter at 5500rpm. And no other dash lights on? I would try and get a OBDII reader on it if you can or get it to a trusted garage to get them to look at it. That seems very odd. Hopefully Adam or Alex will be along shorty with some ideas. Quote Link to comment Share on other sites More sharing options...
roastbeef78 Posted April 24, 2009 Author Share Posted April 24, 2009 No, it does it in 2nd/3rd/4th any gear under hard accleration but not under gentle acceleration. Quote Link to comment Share on other sites More sharing options...
From A to Zed Posted April 25, 2009 Share Posted April 25, 2009 How many miles has your car done budddy? It's a long shot but if you've done >50k on the original spark plugs they could need replacing... Otherwise you may need to bite the bullet and get a specialist / dealer to look at the car. Good luck. Quote Link to comment Share on other sites More sharing options...
Darren-B Posted April 25, 2009 Share Posted April 25, 2009 Does it do it in 6th? Hope you get it sorted with little expense Quote Link to comment Share on other sites More sharing options...
roastbeef78 Posted April 25, 2009 Author Share Posted April 25, 2009 Cheers for your help guys, the car has done just under 52000, not sure about doing it in sixth, don't know anywhere I could get away with going that quickly!! For everyday driving it's fine, it's not that often I will be really accelerating at full pelt to the redline again and again. Might see if I can find a cheap local specialist to have a look. Or just wait until the next service and get them to see. Quote Link to comment Share on other sites More sharing options...
Martin W Posted April 25, 2009 Share Posted April 25, 2009 I no longer have th original dials, but I do remeber that you could play with what I thought was a rev limiter adjuster by using the switches on the left of the instrument binnacle. What did that achieve then? (I have no limiter anymore.) Quote Link to comment Share on other sites More sharing options...
Chris`I Posted April 25, 2009 Share Posted April 25, 2009 I no longer have th original dials, but I do remeber that you could play with what I thought was a rev limiter adjuster by using the switches on the left of the instrument binnacle. What did that achieve then? (I have no limiter anymore.) See above, thats not the limiter, thats the shift light And you must still have a limiter otherwise you'd blow your engine up Quote Link to comment Share on other sites More sharing options...
Martin W Posted April 25, 2009 Share Posted April 25, 2009 I no longer have th original dials, but I do remeber that you could play with what I thought was a rev limiter adjuster by using the switches on the left of the instrument binnacle. What did that achieve then? (I have no limiter anymore.) See above, thats not the limiter, thats the shift light And you must still have a limiter otherwise you'd blow your engine up So when you moved the RPM indiacted between (what was it 5500 and 7ksomething) that just determined when the 'change gear now' light came on? anyway, I've never been "limited" Must just have a flair for changing up ! Quote Link to comment Share on other sites More sharing options...
Chris`I Posted April 25, 2009 Share Posted April 25, 2009 Yes, all it changes is the little light on the dash. You didnt think Nissan would give you access to the rev limiter did you? And you always have and always will be limited Quote Link to comment Share on other sites More sharing options...
Toon Chris Posted April 26, 2009 Share Posted April 26, 2009 How many miles has your car done budddy? It's a long shot but if you've done >50k on the original spark plugs they could need replacing... Otherwise you may need to bite the bullet and get a specialist / dealer to look at the car. Good luck. I agree, that's well worth a look. Engines can rev fine under no load but the spark can break down under heavy load. Whip out a plug and take a look at it, they really shoudl all be changed at 50K but they will be getting crappy at about 40K. Quote Link to comment Share on other sites More sharing options...
