Qas Posted April 21, 2009 Share Posted April 21, 2009 Hi , im new here and need some help, ive just started trying to fix my crashed 350z. i took the front radiator off and tried to move the car forward a little and didnt realize the gearbox oil is cooled through the radiator, all the oil leeked out as i tried to accelerate forward My car is a 2003 jap import automatic. I need to know how much gearbox oil I need, and a rough guide on how to change it. the dealer said its possibly called matic j but were not too sure and said i should comfirm first! Im also after a lot of front end parts so will be needing someone who either has any or knows where to get them.. Thank you! Quote Link to comment Share on other sites More sharing options...
Maccaman Posted April 21, 2009 Share Posted April 21, 2009 Hi & to the forum, though obviously wished it was in better circumstances. Zmanalex will be able to sort some of the parts for you. Quote Link to comment Share on other sites More sharing options...
sunset350z Posted April 21, 2009 Share Posted April 21, 2009 Welcome Qas, you've come to the right place to get your car sorted Quote Link to comment Share on other sites More sharing options...
Martin W Posted April 21, 2009 Share Posted April 21, 2009 Hi , im new here and need some help, ive just started trying to fix my crashed 350z. i took the front radiator off and tried to move the car forward a little and didnt realize the gearbox oil is cooled through the radiator, all the oil leeked out as i tried to accelerate forward My car is a 2003 jap import automatic. I need to know how much gearbox oil I need, and a rough guide on how to change it. the dealer said its possibly called matic j but were not too sure and said i should comfirm first! Im also after a lot of front end parts so will be needing someone who either has any or knows where to get them.. Thank you! Got any pics Qas, where r u from? Quote Link to comment Share on other sites More sharing options...
Qas Posted April 21, 2009 Author Share Posted April 21, 2009 Im from Luton, 21 and love cars, I really need some help getting the stuff for this as I've left it standing all winter how it is. Moneys waiting so if you got the parts im your buyer Quote Link to comment Share on other sites More sharing options...
Martin W Posted April 21, 2009 Share Posted April 21, 2009 i would have thought that Oil quantities would be something that could wait for the moment. What are you plans for the more practical aspects of your rebuild? Quote Link to comment Share on other sites More sharing options...
Ian Posted April 21, 2009 Share Posted April 21, 2009 Quote Link to comment Share on other sites More sharing options...
Qas Posted April 21, 2009 Author Share Posted April 21, 2009 My problem is without being able to move the car to my garage about 12 meters away i cannot get started, Have you ever tried pushed an auto 350z Its impossible lol. The car looks a whole lot worse than it is because ive taken off most parts. It drove home. My father owns a garage and after looking at the car has just told me to get the parts so he can jig and set the front. So any help would be most appreciated. Quote Link to comment Share on other sites More sharing options...
ZMANALEX Posted April 21, 2009 Share Posted April 21, 2009 Might be a good idea to post up a list of the parts required. There are a few of us on here who between us should get you fixed up with all the parts that you require. I am a bit short on body panels at the moment but I would have all the mechanical bits that you require. Cheers, Alex. Quote Link to comment Share on other sites More sharing options...
xStric9x Posted April 21, 2009 Share Posted April 21, 2009 Looks like your going to be busy bud but as Alex says the guys on here will sort you out for the bits you need i'm sure Quote Link to comment Share on other sites More sharing options...
maz77 Posted April 21, 2009 Share Posted April 21, 2009 Hi , im new here and need some help, ive just started trying to fix my crashed 350z. i took the front radiator off and tried to move the car forward a little and didnt realize the gearbox oil is cooled through the radiator, all the oil leeked out as i tried to accelerate forward My car is a 2003 jap import automatic. I need to know how much gearbox oil I need, and a rough guide on how to change it. the dealer said its possibly called matic j but were not too sure and said i should comfirm first! Thank you! not sure of the automatic gearbox tbh. I got mine done last week (manual gearbox). there are to bolts you need remove (with a hex key I think). one is at the bottom of the gearbox and the other one is on the right side of the gearbox casing. you remove both to drain the oil out completely. then bolt the bottom one back on again. you fill the gearbox oil from the side. fill it till it start to spill out as the side bolt opening is at the required oil level. before you try doing any of that confirm with someone on here or your dealer that the auto gearbox has a similar set up to the manual. may I also suggest you get a service manual. I have a similar project car and the service manual is great help. just make sure you get the manual thats relevant to the UK. good luck Quote Link to comment Share on other sites More sharing options...
bronzee Posted April 22, 2009 Share Posted April 22, 2009 the dealer said its possibly called matic j but were not too sure and said i should comfirm first! Yes it is J Matic. There are also other companies that do something almost identical to J Matic as well. Quote Link to comment Share on other sites More sharing options...
Zazur Posted April 22, 2009 Share Posted April 22, 2009 Welcome Qas, Here's what you need and do. The oil is only available from Nissan, you need AT-Matic J Fluid, Nissan part no KE908-99932, it is sold in 1 litre bottles you need about 3 litres and the dealer has to order it. Use the drain plug under the gearbox to empty all the old oil out of the gearbox. When you come to fill it up you will find a tube with a stopper at the back of the engine just in front of the J stamped onto the bulhead. You need a 10mm spanner to remove the nut at the side and the stopper can then be removed which you will then see is a dipstick. Fill it up slowly using a funnel checking the marks on the dipstick and remember do not overfill. Start the engine and run for one min then put the gearbox through P-R-N-D-N-R-P and then switch off engine and check dipstick, fill up repeat as required. Then replace dipstick and replace bolt, job done Quote Link to comment Share on other sites More sharing options...
Qas Posted April 23, 2009 Author Share Posted April 23, 2009 thank you Zazur ! Will try that tonight ! Quote Link to comment Share on other sites More sharing options...
Zazur Posted April 26, 2009 Share Posted April 26, 2009 thank you Zazur ! Will try that tonight ! Hi Qas, Did you get your gearbox oil problem sorted ok?? Quote Link to comment Share on other sites More sharing options...
