Toon Chris Posted April 21, 2009 Share Posted April 21, 2009 Went for a tootle up the coast last night but was on reserve fuel only. Unbelievably I could not find a garage anywhere that has 97 unleaded so had to gently drive back to my local Shell at the end of the evening. I managed to get 79.54 litres in the tank Sh*t! only 100m from conking out on the A1 (in theory) but there were no coughs or splutters, even going around corners. Quote Link to comment Share on other sites More sharing options...
Lexx Posted April 21, 2009 Share Posted April 21, 2009 Ive had a similar problem! Couldnt find a single Shell garage from Seahouses, all the way back to the center! Quote Link to comment Share on other sites More sharing options...
Beavis Posted April 21, 2009 Share Posted April 21, 2009 You would have been fine with a drop of the weak stuff to get you back if you had no alternative Quote Link to comment Share on other sites More sharing options...
dcash5 Posted April 21, 2009 Share Posted April 21, 2009 My mate, with an old audi 80 was that close to running out of few he had to dilute what was left with redex to the nearest petrol station. I have never seen a car smoke so much!!! But then again it ran like a dream with a full tank and some very clean pipes! Quote Link to comment Share on other sites More sharing options...
Marios Posted April 21, 2009 Share Posted April 21, 2009 I used to only Shell Optimax in but now I use standard 95 and I see absolutly no difference in performance or fuel consumption Quote Link to comment Share on other sites More sharing options...
Toon Chris Posted April 21, 2009 Author Share Posted April 21, 2009 You would have been fine with a drop of the weak stuff to get you back if you had no alternative Only if really desperate I can't say i can detect any better performance with 97 over 95, but the mpg is slightly higher and enough to offset the extra cost, so why not use it Quote Link to comment Share on other sites More sharing options...
matth76 Posted April 22, 2009 Share Posted April 22, 2009 I used to only Shell Optimax in but now I use standard 95 and I see absolutly no difference in performance or fuel consumption Not a good idea running on the standard 95 long term as you are very likely going to be having pinking going on undetected which causes premature engine damage. Most Tesco superunleaded pumps (offering both 99 ron and 97) are actually cheaper than regular 95 pumps at main stream garages. Quote Link to comment Share on other sites More sharing options...
sl114 Posted April 24, 2009 Share Posted April 24, 2009 So how much do you get to a tank now? Quote Link to comment Share on other sites More sharing options...
Toon Chris Posted April 24, 2009 Author Share Posted April 24, 2009 So how much do you get to a tank now? I average just under 30mpg so that's 500 miles per tank, although I rarely run it as low as I did that time. On the 95 it was about 2mpg less. If you calculate that the 97 fuel costs about 4p more per litre it makes the price per mile nearly a penny less. Um, ish. Not scientificly accurate but near enough that i don't bother with the cheap stuff :0 Quote Link to comment Share on other sites More sharing options...
DJsickboy Posted April 24, 2009 Share Posted April 24, 2009 So how much do you get to a tank now? I average just under 30mpg so that's 500 miles per tank, although I rarely run it as low as I did that time. On the 95 it was about 2mpg less. If you calculate that the 97 fuel costs about 4p more per litre it makes the price per mile nearly a penny less. Um, ish. Not scientificly accurate but near enough that i don't bother with the cheap stuff :0 How the hell do you average just under 30mpg??? I struggle to get more than 22...!! Quote Link to comment Share on other sites More sharing options...
Fien Posted April 24, 2009 Share Posted April 24, 2009 I'm the same. Dont think i've ever seen it over 28! think i'm averaging about 21 at the mo although i do alot of city driving. Quote Link to comment Share on other sites More sharing options...
mac1984 Posted April 24, 2009 Share Posted April 24, 2009 I've just worked out my MPG, and it's 24.8 mpg and 338miles before the light came on. Not bad for a mix of city, motorway, and pratting about Quote Link to comment Share on other sites More sharing options...
