OE Bumper repair / replacement
H5
Hi all,
After my message saying mine is on it's way, there's been delays ever since! There was a scuff on the front bumper (high kerb the culprit apparently) and the owner kindly put it in to have it repaired. When the repair was started they found there was a slight crack in it so the current owner has bought a new bumper (in the process breaking the washer jets that are apparently £248 each from Nissan! :scare: )
What I need to know is, is there anything I should be checking for when I go and inspect the car? Weak points, common bodges etc? Last thing I want is a repair bill when things may have been missed.
Thanks.
Basically fully inspect the car before you drive away! If there's anything at all your not happy about, report it and make sure it is fixed to your liking. It will of had a PDI so hopefully everything is ok.
If at the end of the day you don't walk away with one of these - :D
There's a serious problem. Anyway stop worrying and enjoyyy :yahoo:
