passenger grab handle
complete passenger grab handle (aliminium strip as pictured + black plastic handle not pictured)
there are a few minor scratches that i've tried to photograph, i'd guess most would be removed with autosol.
looking for £20 inc postage
To get this off is it a case of literally just prising it off or is there a special technique? I need to have a go at polishing mine up.....
To remove you you need a small flat blade screwdriver. Insert the screwdriver behind the metal strip at the top towards the engine bay. Then just prise it out. It is stronger than it looks but be careful its very easy to slip and scratch it. If you want to remove the handle also it can be removed with a long 10mm ratchet or philips screwdriver.
cheers mark, might have a go at doing mine :thumbs:
