Trev-the-Rev Posted April 16, 2009 Share Posted April 16, 2009 I've just bought a set of Mintex 1144 pads for the rear and in the box are 4 rubber pads the same shape as the brake pads. Where do these go and do I still use the original anti squeal shims? Quote Link to comment Share on other sites More sharing options...
H5 Posted April 16, 2009 Share Posted April 16, 2009 Are the rubber pads there to protect the brake pad material in transit or separate for install? I can't see rubber pads helping a huge amount in brakes unless it's some new development.... Quote Link to comment Share on other sites More sharing options...
Trev-the-Rev Posted April 16, 2009 Author Share Posted April 16, 2009 Are the rubber pads there to protect the brake pad material in transit or separate for install? I can't see rubber pads helping a huge amount in brakes unless it's some new development.... They're seperate for install and are self adhesive on one side suggesting they should be stuck to the back of the pad!!! Quote Link to comment Share on other sites More sharing options...
MITZ@CougarStore Posted April 16, 2009 Share Posted April 16, 2009 Correct, you can stick them to the back of the pad, most come with them already in situation... Make sure you also use the original shims too... Quote Link to comment Share on other sites More sharing options...
Trev-the-Rev Posted April 16, 2009 Author Share Posted April 16, 2009 Thanks for the advice Quote Link to comment Share on other sites More sharing options...
