Ian Posted April 16, 2009 Share Posted April 16, 2009 well sort of fitted, Just need to figure out the best way to run the cable The unit Unit fitted Cable is small enough not to stick out from OBD port Only things that it doesn't pick up is Manifold Pressure & Ignition timing At the moment the first 3 settings are set to - MPH, Battery Voltage & RPM. Intake temp Engine Load MPG Throttle position Water Temp No Codes Just waiting for my CEL to come back on now so I can test the code reading part of it Any ideas on the best way to route the cable? Current plan is to maybe run it behind the dash Quote Link to comment Share on other sites More sharing options...
3FIDDYZ Posted April 16, 2009 Share Posted April 16, 2009 Nice one mate. That was quick! I ran mine from the odb2 to the camp2 behind the dash, there is a hole that is already there What other info is it giving out and can you set alarms when you reach certain temps / limits? Quote Link to comment Share on other sites More sharing options...
Ian Posted April 16, 2009 Author Share Posted April 16, 2009 Nice one mate. That was quick! I ran mine from the odb2 to the camp2 behind the dash, there is a hole that is already there What other info is it giving out and can you set alarms when you reach certain temps / limits? No alarms. Only other info is the manifold pressure & Ignition timing but they dont work on the Z. Also has a trip computer but untill I fill the car up I cant set that up. Trip computer when setup shows * Maximum Speed * Average Speed * Maximum Coolant Temperature * Maximum RPM * Driving Time * Driving Distance * Fuel Used * Trip Fuel Economy * Distance to Empty * Time to Empty * Fuel to Empty Gonna fiddle around with the Xgauge part of it once its all fited properly I'll have a look for the hole later Quote Link to comment Share on other sites More sharing options...
marzman Posted April 16, 2009 Share Posted April 16, 2009 That looks cool... i like it. What does the rest of it look like? Mount it on your sunglasses holder if you can still see it up there...? Quote Link to comment Share on other sites More sharing options...
Ian Posted April 16, 2009 Author Share Posted April 16, 2009 That looks cool... i like it. What does the rest of it look like? Mount it on your sunglasses holder if you can still see it up there...? Possibly but where it is now makes it easier to access, there is an attachment you can buy to mount it to the rearview mirror. As for the rest of it, its not a lot bigger than what you see. 2 Connectors 1 at the back ?& 1 at the side. Quote Link to comment Share on other sites More sharing options...
Martin W Posted April 16, 2009 Share Posted April 16, 2009 Nice one mate. That was quick! That was bloddy quick! wasn't it last night you pm'd me about this? saying you thought you were going to get 1 ? Quote Link to comment Share on other sites More sharing options...
Ian Posted April 16, 2009 Author Share Posted April 16, 2009 Ordered it about 8.30 tuesday night & was delivered this morning Quote Link to comment Share on other sites More sharing options...
