GT4 Zed Posted April 14, 2009 Share Posted April 14, 2009 I have read and cleared this code which came on starting the Zed in the morning on two occasions now(~3 weeks apart). There was a slight hesitation as i turned on the ignition then the engine barked into life followed by the engine check light a few seconds later.The car runs fine and a routine check was fine. The only recent change is the MREV2 which was installed almost a month ago and a P3 service. I had iridium sparkies put in place of platinum. Any ideas on why i am having this error codes thrown up or is it spurious What actions should i take next. cheers people Quote Link to comment Share on other sites More sharing options...
slinky Posted April 15, 2009 Share Posted April 15, 2009 I'd go with a slightly dodgy connection on the lambda sensor.. We'll scan it when you're back in Worcs and have a nose to see whether there are any other codes getting generated.. Quote Link to comment Share on other sites More sharing options...
