jpaero Posted April 14, 2009 Share Posted April 14, 2009 Just wondering has anyone used a Greddy Emanage or an Ultimate on their 350z. Would like to know if this would be a good or as good as another ecu piggyback? Quote Link to comment Share on other sites More sharing options...
Ekona Posted April 14, 2009 Share Posted April 14, 2009 Not on the Zed, but I've used an EMB on previous cars with success. I quite like 'em, even if the tuning software is somewhat clunky and you have to have a really good match between the EMB firmware and the support tool else it won't read the maps. Hardware-wise I've had no issues with it at all, and there's certainly enough there to do what you need it to do unless you're having a custom built engine or something (but then if you were, you'd go full standalone not piggyback). The EMU Ultimate is by far the better option now though given the extra features, and it's certainly something I'd be considering were I in a position to do so. I think most people with a Zed tend to run either a Haltech or a UTech as their choice of programmable widgets, I have no personal experience of these on the 350 though. Quote Link to comment Share on other sites More sharing options...
jpaero Posted April 14, 2009 Author Share Posted April 14, 2009 See i have used the Blue emanage previously also. I thought the ultimate for the 350 might be good but wasnt sure if it would give the same gains as haltech etc. Certainly is the cheaper option though. Quote Link to comment Share on other sites More sharing options...
Ekona Posted April 14, 2009 Share Posted April 14, 2009 It'll give just as good gains, it's all tuner-dependant. Some are better than others, and if you can find a good one then you're laughing. All you're doing basically is balancing the AFR with the timing to produce the most power with the least knock, so it's quite possible to map a car yourself if you're confident to give it a go. I can happily play with maps to get to smooth them out a bit, but I could never map a car from nothing. Quote Link to comment Share on other sites More sharing options...
jpaero Posted April 14, 2009 Author Share Posted April 14, 2009 I already have a apexi safc in the car. Would this kind of be the same thing for the 350. Quote Link to comment Share on other sites More sharing options...
Chris`I Posted April 14, 2009 Share Posted April 14, 2009 I already have a apexi safc in the car. Would this kind of be the same thing for the 350. Gets you half way there from what I understand. It makes the AFR correct (or as close as possible) but thats where it stops. Piggyback ECUs allow you access to other things such as timing advance which get you more power. So short answer is it does some of it Quote Link to comment Share on other sites More sharing options...
jpaero Posted April 14, 2009 Author Share Posted April 14, 2009 so then next question is, would you recommend it for the gains it would get you? And for the cost etc. Quote Link to comment Share on other sites More sharing options...
Chris`I Posted April 14, 2009 Share Posted April 14, 2009 That would require someone with more knowledge than I Wait for Adam and co for the answers on that one Quote Link to comment Share on other sites More sharing options...
jpaero Posted April 14, 2009 Author Share Posted April 14, 2009 ok, thanks Chris! Quote Link to comment Share on other sites More sharing options...
Ekona Posted April 14, 2009 Share Posted April 14, 2009 Personally I'd find a local reputable tuner and ask them what system they personally prefer using. It may be that the Haltech Platinum is a far more capable piece of kit than the EMB (actually, it is!) but if the tuner doesn't like it/hasn't got the equipment to access it, then it's pointless fitting one. If you know someone good who's familiar with the EM range, then I'd be tempted to stick with that. The only question mark I would have is whether there's a loom available for the EM for the Zed, as you don't really want top be hacking into the stock ECU loom unless it's a last resort. Quote Link to comment Share on other sites More sharing options...
Adam@Z1auto.com Posted April 15, 2009 Share Posted April 15, 2009 I already have a apexi safc in the car. Would this kind of be the same thing for the 350. Gets you half way there from what I understand. It makes the AFR correct (or as close as possible) but thats where it stops. Piggyback ECUs allow you access to other things such as timing advance which get you more power. So short answer is it does some of it Based on how the SAFC works it (unfortunately) also alters timing maps as well. Problem is, you have zero control over it (as you lean the car out, timing advances, as you richen it up, timing retards). Biggest issue is that since it has no drivers and is just manipulating maf voltage, you only have a very very small window for changes. Based on other alternatives out there, I'm personally not a fan. Especially considering that once you add in the various widgets to truly make it compete with the plug and play options, it really doesn't end up much less expensive either Quote Link to comment Share on other sites More sharing options...
jpaero Posted April 15, 2009 Author Share Posted April 15, 2009 well guess that somes it up, speed money on other things lol. Thanks for the comments guys! Quote Link to comment Share on other sites More sharing options...
