Alarm LED wiring
nothingz
My alarm LED on the dash wasnt connected, or I should say when I take the LED out using a flat head screwdriver, the wire is not attached and nowhere to be seen inside the hole!
Now I am thinking maybe I can run my own wire to the alarm module to connect it up again, but I will need alot of help...for example location of the alarm module? Wiring diagram for the LED blinking? etc
My zed is a 2007 facelift model, with stock alarm system.
2nd question is, I also take out the passenger side, and there is a wire attached to it, what is that? It does not light up or anything. The plug is different than the LED one.
Thanks.
