xStric9x Posted April 7, 2009 Share Posted April 7, 2009 Hi all, bit of help needed. Windscreen wash motor only works for the back window, when i pull the stork towards me for the front window there is silence and only wipers moving. Any ideas? Quote Link to comment Share on other sites More sharing options...
M13KYF Posted April 7, 2009 Share Posted April 7, 2009 have you checked the fuses Quote Link to comment Share on other sites More sharing options...
Mitchell Posted April 7, 2009 Share Posted April 7, 2009 There are two motors, one for front and one for back. try swaping connections round to test see if it is the pump thats gone. Quote Link to comment Share on other sites More sharing options...
xStric9x Posted April 7, 2009 Author Share Posted April 7, 2009 There are two motors, one for front and one for back. try swaping connections round to test see if it is the pump thats gone. Thats what i wasn't sure about will go and have a look, and will also check fuses Quote Link to comment Share on other sites More sharing options...
M350ZB Posted April 7, 2009 Share Posted April 7, 2009 Do you get any motor sound at all, when using the front windscreen, if you dont that would suggest a fuse to me, well 1st step to take, if the motor is making a noise, is it winning ? Quote Link to comment Share on other sites More sharing options...
M13KYF Posted April 7, 2009 Share Posted April 7, 2009 Do you get any motor sound at all, when using the front windscreen, if you dont that would suggest a fuse to me, well 1st step to take, if the motor is making a noise, is it winning ? there is silence Quote Link to comment Share on other sites More sharing options...
M350ZB Posted April 7, 2009 Share Posted April 7, 2009 Sorry my bad, well first off check the fuse, if that fails, make sure all connections are made bud Quote Link to comment Share on other sites More sharing options...
xStric9x Posted April 7, 2009 Author Share Posted April 7, 2009 Now its working and i've not really done anything Will keep my eye on it over the next few days. Quote Link to comment Share on other sites More sharing options...
NWZ Posted April 7, 2009 Share Posted April 7, 2009 How strange! Maybe the zed is just after your attention Mike Quote Link to comment Share on other sites More sharing options...
xStric9x Posted April 7, 2009 Author Share Posted April 7, 2009 How strange! Maybe the zed is just after your attention Mike Not had a very good spray for a while, i've had the lines out and cleaned them but it not made any difference so maybe the pump is on the way out Quote Link to comment Share on other sites More sharing options...
M350ZB Posted April 7, 2009 Share Posted April 7, 2009 Now its working and i've not really done anything Will keep my eye on it over the next few days. Odd Quote Link to comment Share on other sites More sharing options...
Komier Posted April 9, 2009 Share Posted April 9, 2009 Mine is doing exactly the same thing. Work's sometimes and not others, and the spray at the front has been kinda pitiful recently. Quote Link to comment Share on other sites More sharing options...
xStric9x Posted April 9, 2009 Author Share Posted April 9, 2009 Mine is doing exactly the same thing. Work's sometimes and not others, and the spray at the front has been kinda pitiful recently. I will investigate and get back to you unless you find something first Quote Link to comment Share on other sites More sharing options...
M350ZB Posted April 9, 2009 Share Posted April 9, 2009 You do all know, the washer jets only come out every three times on the stalk within the car, but should allways come on when pushing the windcreen button Quote Link to comment Share on other sites More sharing options...
xStric9x Posted May 28, 2009 Author Share Posted May 28, 2009 Still having major problems with this, if i am able to switch the terminals around could somebody point out where they are please? Quote Link to comment Share on other sites More sharing options...
Mitchell Posted May 29, 2009 Share Posted May 29, 2009 behind the front bumper, to the front of the drivers front wheel. should be able to take the arch liner out and get straight to them. on a jack might help Quote Link to comment Share on other sites More sharing options...
xStric9x Posted May 29, 2009 Author Share Posted May 29, 2009 behind the front bumper, to the front of the drivers front wheel.should be able to take the arch liner out and get straight to them. on a jack might help Thanks bud, i managed to find it and have now come to the conclusion its pooped. As a quick fix i have changed the lines around as the plugs are different sizes front and rear. Quote Link to comment Share on other sites More sharing options...
H5 Posted May 30, 2009 Share Posted May 30, 2009 Try the default R35LEE for a replacement mate. Although I have to say I am tempted to just take the washer bottle out of my car, I don't use it at all! Quote Link to comment Share on other sites More sharing options...
chocohercules Posted June 2, 2009 Share Posted June 2, 2009 Hi Guys i too have the same problem but front and back squirters arent working where is the fuse box for window washers? is it in the driverside compartment or the engine bay, cheers. Quote Link to comment Share on other sites More sharing options...
