ECU error code 1167
hagar
suspected it was that as I was told to watch out for the rear Ox sensors after changing the cats
it popped up after a month, the car was working fine, stopped to put fuel in and it came on - reset the code and not appeared since.
Do you have a link to the codes as my scanner book only lists the standard not manufacturer codes
thanks
i think its the post cat sensor so maybe still possible to throw up the code
quite a few have mentioned this code coming up for no reason other than faulty sensors
only done it once, if it comes on again I'll check the sensor out
