matth76 Posted March 30, 2009 Share Posted March 30, 2009 Has anyone else experienced scratches on their passenger or driver windows? I have vertical scratches (quite a few) each about 4 cms long all along the top of the passenger window, across the width of the window as though over the last three years it has been catching on some metal across the width of the window in the door. Is this covered under warranty (it is definitely not normal wear and tear because my last car was 12 yrs old and had perfect windows)? When the window does close or open it appears quiet but clearly has been catching on something over the 4yr life of the car. Also my driver window does not close properly (there is a small gap about 1mm between the rubber rim and the glass) - it is noticable when driving at 70 mph.. really hear the wind whistle, and when I wash the car it occasionally leaks. I can see it is the rubber bit along the top of the window which is at fault.. it does not securely cover the top of the window. I have heard this is a common issue - so is this covered under extended mfr warranty (same as the scratched glass above)? Thanks for any info. Quote Link to comment Share on other sites More sharing options...
stanski Posted March 31, 2009 Share Posted March 31, 2009 Best thing to do is ask your local friendly Nissan dealer and explain the situation to them? I guess it will be - definitely the window not shutting correctly? Worse case if they dont do it get some T-Cut glass polish - it really does work - just like normal T Cut but for glass. Good luck with it and let us know how you get on? Quote Link to comment Share on other sites More sharing options...
matth76 Posted March 31, 2009 Author Share Posted March 31, 2009 Cheers Stan. T-cut glass polish - I know what I'm doing this weekend Thanks for your help. Quote Link to comment Share on other sites More sharing options...
Zee Posted March 31, 2009 Share Posted March 31, 2009 When I read the OP It freaked me out, word for word you described the exact same problems I encountered yesterday! SoO Cheers Matth76 for saving me the time to type it out and cheers stan I'll grab some glass T-Cut! The scratches arnt deep, it looks like there was some grit wedged into the seal on the drivers side. Most of the scratches are located towards the top of the glass. Quote Link to comment Share on other sites More sharing options...
webber Posted July 23, 2009 Share Posted July 23, 2009 Sorry to dig up an old thread but I was curious...did the T Cut glass work? I've got very similar small vertical scratches on both windows and I'm hoping that this may get rid or at least reduce them. Quote Link to comment Share on other sites More sharing options...
jerry3167 Posted July 23, 2009 Share Posted July 23, 2009 Think the scratch issue is a common thing with Zed windows, I have very fine ones both windows. Quote Link to comment Share on other sites More sharing options...
sunset350z Posted July 23, 2009 Share Posted July 23, 2009 I've got scratches on my windows too. Will give the t cut a try tomorrow but it wont do much for the deeper ones. My drivers window doesn't close properly sometimes either. Its like a speed sensor, soon as i hit 85mph the wind starts howling in I have to lift the window switch to close the window but it eventually drops again. Its only a tiny amount maybe 1 or 2 mm max but its enough to irritate me. May need to try the widow reset procedure but not convinced that'll work. Quote Link to comment Share on other sites More sharing options...
Dblock Posted July 24, 2009 Share Posted July 24, 2009 i have heard some people wet sanding and polishing and some peopel just using an arbrasive polish but keep spraying the screen with water or the plastic inbetween the screen will haze and go white. Quote Link to comment Share on other sites More sharing options...
GT4 Zed Posted July 24, 2009 Share Posted July 24, 2009 I've got scratches on my windows too. Will give the t cut a try tomorrow but it wont do much for the deeper ones. My drivers window doesn't close properly sometimes either. Its like a speed sensor, soon as i hit 85mph the wind starts howling in I have to lift the window switch to close the window but it eventually drops again. Its only a tiny amount maybe 1 or 2 mm max but its enough to irritate me. May need to try the widow reset procedure but not convinced that'll work. Steve, you have a way of finding the positives to problems ......speed sensor??? I have the same issue now ll the time and no change after reset procedure. The stealers know about the problem but you have to fork out for new weather strip rubbers The wind actually goes out.....venturi effect Quote Link to comment Share on other sites More sharing options...
matth76 Posted July 26, 2009 Author Share Posted July 26, 2009 £200 for the rubber strip / window seal!!! I've decided to drive slower or put up with the whistle. It's a common problem and in a car that's 3.5 yrs old should not have this kind of thing happening under "wear and tear" - yet Nissan refuse to fix it under mfr warranty which I have. Quote Link to comment Share on other sites More sharing options...
harrier1 Posted July 26, 2009 Share Posted July 26, 2009 glad i saw this be getting the t cut asap now cheers Quote Link to comment Share on other sites More sharing options...
Fien Posted July 27, 2009 Share Posted July 27, 2009 they do T-cut for windows???! I never had a clue I've got some small scratches on my windows but just thought they wouldnt be that easy to clean up. Has any one used this yet and what are there opinions? Quote Link to comment Share on other sites More sharing options...
webber Posted July 29, 2009 Share Posted July 29, 2009 I tried the Tcut but it didnt work, the scratches are too deep on mine, i can feel them if i run over them with my nail. I've seen a thread on detailing world which was interesting: http://www.detailingworld.co.uk/forum/s ... hp?t=95965 I'm considering trying this kit...or possibly trying the T-cut with a buffer and a felt pad which may work better possibly?! Quote Link to comment Share on other sites More sharing options...
sunset350z Posted July 30, 2009 Share Posted July 30, 2009 Seems like this is the kit to go for http://www.4wheelplay.co.uk/liquid-glas ... 02760.html I tried the t-cut, but it still left the deeper scratches. It is a great glass polisher though and i will continue using it. Quote Link to comment Share on other sites More sharing options...
webber Posted July 30, 2009 Share Posted July 30, 2009 That looks like a good kit.... I've ordered some felt buffing pads already so i'm going to give the T-cut a go with them first. If that doesnt work then I'll be ordering that kit i think ...and if that doesnt work I'll just have to get over it! and accept that my car has scratched windows Quote Link to comment Share on other sites More sharing options...
varley16 Posted May 21, 2011 Share Posted May 21, 2011 digging up this old thread, did any of the above work? Quote Link to comment Share on other sites More sharing options...
leonk Posted May 21, 2011 Share Posted May 21, 2011 +1 on results info. Been looking at various products on E bay but not sure how effective. Quote Link to comment Share on other sites More sharing options...
