Algae: A Detail issue with a difference
Martin W
I have seen a few posts about condensation in the headlamps
and Nissans's statement that it is not unusual for this to happen
However, I have a slightly dirty inside to the headlamps, and what
seems to be a slight ALgal green tinge INSIDE the main glass
Anyone else had this problem? How do I go about getting the inside cleaned
Is it possible without getting the oven hot and baking the lights apart?
Any ideas welcome :thumbs:
Got a pic? The lense does have a UV type filter on it and can give a purple/green tint to it, but not quite what you describe.
Due to the construction of the headlamp, I wouldnt expect you to be able to do much without baking it and taking it apart. Might be a good excuse to get Paul to work his magic B)
I'll try in daylight. I thought baking would be the only answer.
Damned expensive way of cleaning the glass though !!
Why don't you flick P15ULT a pm, he would probably know the quick way to get the headlights apart. ;)
Think baking it is the only way. Pretty much the same on all headlamps. I know I would rather Paul did it as he has done many before and a good excuse to get some work done :teeth:
