wide Posted March 24, 2009 Share Posted March 24, 2009 my aircon is steaming up the windows when circulating, but its fine on the other mode, what would cause this? thanks matt. Quote Link to comment Share on other sites More sharing options...
M13KYF Posted March 24, 2009 Share Posted March 24, 2009 your manual say that you should set it to intake from outside to demist rather than circulate. You will be just pushing arounf the same moist air Quote Link to comment Share on other sites More sharing options...
wide Posted March 24, 2009 Author Share Posted March 24, 2009 im on about when the windows aren't misted up! if i put it on circilate they mist up, that can't be normal sorry. Quote Link to comment Share on other sites More sharing options...
lomoto Posted March 24, 2009 Share Posted March 24, 2009 im on about when the windows aren't misted up! if i put it on circilate they mist up, that can't be normal sorry. yes thats normal , to stop the misting you must have fresh air going through the air con unit..otherwise your just recirculating moisture that the system cant cope with... thats why on most climate control units it automatically switchs to fresh air input when you want to demist your screen...stop whittling it's normal have you had an air con equiped car before ?? Quote Link to comment Share on other sites More sharing options...
Maccaman Posted March 24, 2009 Share Posted March 24, 2009 Press the control button for circulate or fresh air for a couple of seconds and it will automatically select what is needed. Quote Link to comment Share on other sites More sharing options...
wide Posted March 24, 2009 Author Share Posted March 24, 2009 im on about when the windows aren't misted up! if i put it on circilate they mist up, that can't be normal sorry. yes thats normal , to stop the misting you must have fresh air going through the air con unit..otherwise your just recirculating moisture that the system cant cope with... thats why on most climate control units it automatically switchs to fresh air input when you want to demist your screen...stop whittling it's normal have you had an air con equiped car before ?? yes thanks ive had quite a few & never experienced this before! Quote Link to comment Share on other sites More sharing options...
