neil2185 Posted March 24, 2009 Share Posted March 24, 2009 Ok so I have a pretty good system for getting my car clean I wash then clay to remove the very fine dirt then wash then dry then polish with filers to hide some small swerl marks (previous owner) then sometimes glaze and then wax or seal. However my question is that I have removed the dirt from the fine scratches with the clay, filled them with something using the polish and sealed that process in using the wax or seal and it looks but how often do I need to do that, ie go to the trouble of polish and clay, and what can I do imbetween? Could I just wash dry and wax if I use a wax friendly shampoo to clean off surface dirt and restore shine when I dont have time to do the big process and want to get the car looking good again Cheers Neil Quote Link to comment Share on other sites More sharing options...
H5 Posted March 24, 2009 Share Posted March 24, 2009 Moved You probably only want to clay the car a couple of times, maybe 3 times a year really. If you clay it, polish and put a good sealant on before waxing, you should get a good few months of protection. Then the interim washes can just be a wax friendly wash and top up of the wax. Quote Link to comment Share on other sites More sharing options...
neil2185 Posted March 24, 2009 Author Share Posted March 24, 2009 Oh and also, when I decide I do want to polish and clay again what can I use to remove the wax as obviously there is no point polishing and claying with the wax or seal still on the car Quote Link to comment Share on other sites More sharing options...
BulletMagnet Posted March 24, 2009 Share Posted March 24, 2009 According to the Detailing Guide on here, you can get away with claying every 3 months viewtopic.php?f=22&t=2878 Give that a good read Quote Link to comment Share on other sites More sharing options...
H5 Posted March 24, 2009 Share Posted March 24, 2009 If you look at most decent washes, they will have two dilution levels on them. One for a 'strip clean' and one for a gentle clean. This can be quite a difference - my Chemical Guys citrus wash n gloss barely needs more than a cap full in a bucket to strip the car! Always read the label, as they say! Once you have given the car a good wash, or snow foamed the car, then you will have stripped away the wax. Quote Link to comment Share on other sites More sharing options...
neil2185 Posted March 24, 2009 Author Share Posted March 24, 2009 ok cool, so what can I do for a quick wash if I dont want to go down the whole process of wash clay polish glaze wax/seal, any suggestions for a quick wash? Quote Link to comment Share on other sites More sharing options...
H5 Posted March 24, 2009 Share Posted March 24, 2009 Do you mean product or process?? Quote Link to comment Share on other sites More sharing options...
BulletMagnet Posted March 24, 2009 Share Posted March 24, 2009 The quick wash will basically entail rinse, wash, dry and wax, that's it (I'm glad the Zed isn't bigger than it is...) Quote Link to comment Share on other sites More sharing options...
H5 Posted March 24, 2009 Share Posted March 24, 2009 According to the Detailing Guide on here, you can get away with claying every 3 months viewtopic.php?f=22&t=2878 Give that a good read You need to be slightly careful with that guide. It recommends polishing every month - depending on the product being used, you don't need / want to be doing that. Quote Link to comment Share on other sites More sharing options...
BulletMagnet Posted March 24, 2009 Share Posted March 24, 2009 Well anything is to be taken with a pinch of salt and a dose of common sense. Maybe a detailer or washing enthusiast could make an updated guide? Quote Link to comment Share on other sites More sharing options...
H5 Posted March 24, 2009 Share Posted March 24, 2009 Well anything is to be taken with a pinch of salt and a dose of common sense.Maybe a detailer or washing enthusiast could make an updated guide? Will put it on the list of things to update once the new forum niggles have been ironed out. Quote Link to comment Share on other sites More sharing options...
srobrien Posted March 24, 2009 Share Posted March 24, 2009 Claying will remove everything from your paint including wax's so you want to be doing that as little as possible. I add wax whenever I have time, a few times a month, just to build up the layers of protection. When you are cleaning use LSP (last stage product) safe cleaners to ensure you don't strip the wax you have spent so long applying. If you DO want to remove the wax whilst washing (prior to claying) then use a more concentrated dilution of all purpose cleaner. R Quote Link to comment Share on other sites More sharing options...
neil2185 Posted March 30, 2009 Author Share Posted March 30, 2009 Any suggestions of a good lsp safe cleaner? Quote Link to comment Share on other sites More sharing options...
scottsoulby Posted March 30, 2009 Share Posted March 30, 2009 dodo juice born to be natural is a good shampoo, its ph neutral so should be fine for waxes Quote Link to comment Share on other sites More sharing options...
