fatalus Posted April 14, 2009 Share Posted April 14, 2009 also got my turbo grooved discs fitted this weekend from CS. Very nice Did you notice any increased noise or vibrations with these btw? Quote Link to comment Share on other sites More sharing options...
Dave_McC Posted April 16, 2009 Share Posted April 16, 2009 To answer the original question, I've just been quoted £730 all in for new rear disks and pads fitted. Can't remember exact breakdown, but disks were about £185 each, pads were about £145 for the set, there was some sort of shim set at £45 odd and 1.5 hours labout to fit at about £80 an hour. Pretty shocked by that really - car has only done 32k miles - suspicion is that one of the calipers stuck as it was only the inner nearside pad which had worn down to the metal and wrecked the disk. Worst bit is it failed the MoT as a result - and Nissan now won't let me drive the car away. Dave Quote Link to comment Share on other sites More sharing options...
MITZ@CougarStore Posted April 16, 2009 Share Posted April 16, 2009 Dave, £730 would get you a full set of front and rear discs and pads with quite a bit of change back in your pocket if you decided to buy away from Nissan… Lots of better options available for close to £500.00 for full front and rear set... Quote Link to comment Share on other sites More sharing options...
M13KYF Posted April 17, 2009 Share Posted April 17, 2009 also got my turbo grooved discs fitted this weekend from CS. Very nice Did you notice any increased noise or vibrations with these btw? no vibration, with the window down you can here the pads run over the grooves like a faint ticking but nothing bad, only good Quote Link to comment Share on other sites More sharing options...
