Zazur Posted March 18, 2009 Share Posted March 18, 2009 HELP Driving my car today and went to park the car and while parking I moved the box from R to D and the gear shift went straight into the manual gate and it's STUCK! The gear shift is stuck in the manual side of the auto box BUT it is in neutral, the square display says nothing and if I try and move the gear shift to the D position if I hold it as far as it will go towards the D then the N in the display lights but as soon as I let go of the shift the display goes blank. The gearbox is in neutral ( the car rolls no problem). I cannot move the gearshift from the manual side of the box to the D side no matter what I try, the button, the shift lock push button. So now the car is parked up with the keys stuck in the ignition. Anyone got any ideas please?? Quote Link to comment Share on other sites More sharing options...
jim Posted March 18, 2009 Share Posted March 18, 2009 HELP Driving my car today and went to park the car and while parking I moved the box from R to D and the gear shift went straight into the manual gate and it's STUCK! The gear shift is stuck in the manual side of the auto box BUT it is in neutral, the square display says nothing and if I try and move the gear shift to the D position if I hold it as far as it will go towards the D then the N in the display lights but as soon as I let go of the shift the display goes blank. The gearbox is in neutral ( the car rolls no problem). I cannot move the gearshift from the manual side of the box to the D side no matter what I try, the button, the shift lock push button. So now the car is parked up with the keys stuck in the ignition. Anyone got any ideas please?? Have you tried driving it in manual mode? Quote Link to comment Share on other sites More sharing options...
marzman Posted March 18, 2009 Share Posted March 18, 2009 Just googled it... it doesnt sound good... new transmission possibly http://www.justanswer.com/questions/udea-nissan-350z-2004-automatic-sudden Quote Link to comment Share on other sites More sharing options...
Zazur Posted March 18, 2009 Author Share Posted March 18, 2009 Have you tried driving it in manual mode? Hi Jim Nothing in the square display and the car is in neutral so it can't be driven Quote Link to comment Share on other sites More sharing options...
jim Posted March 18, 2009 Share Posted March 18, 2009 Have you tried driving it in manual mode? Hi Jim Nothing in the square display and the car is in neutral so it can't be driven What I mean is, have you tried starting it up and moving the shift forward to engage a gear even though there is no light in the display? Apologies if I am stating the obvious and you have already tried all this. Quote Link to comment Share on other sites More sharing options...
Zazur Posted March 18, 2009 Author Share Posted March 18, 2009 Just googled it... it doesnt sound good... new transmission possibly http://www.justanswer.com/questions/udea-nissan-350z-2004-automatic-sudden Hi marzman, Thanks, as I wrote the autobox shift is stuck in the manual gate position and i cant get it to move across to the D position. Correct me if I am wrong but the link you posted was for the shift being stuck in the park position, and you can move it out of this position with the shift lock button, mine is stuck in the manual side of the box but with no gears engaged. Can someone tell me if when you move the shifter across from A to manual mode as it crosses the gate is their any movement felt from the shifter ie-you feel it slightly raise up or down etc???? Thanks Quote Link to comment Share on other sites More sharing options...
Zazur Posted March 18, 2009 Author Share Posted March 18, 2009 Have you tried driving it in manual mode? Hi Jim Nothing in the square display and the car is in neutral so it can't be driven What I mean is, have you tried starting it up and moving the shift forward to engage a gear even though there is no light in the display? Apologies if I am stating the obvious and you have already tried all this. Hi Jim, Thanks for the imput. If i push the stick towards the D as far as I can then the display lights the N, but as soon as I let the stick go, the screen goes blank and if I push the stick forward or back in the manual mode I can hear the soleniods clicking but no gears engaged. Any thoughts??? Quote Link to comment Share on other sites More sharing options...
jim Posted March 18, 2009 Share Posted March 18, 2009 Just googled it... it doesnt sound good... new transmission possibly http://www.justanswer.com/questions/udea-nissan-350z-2004-automatic-sudden Hi marzman, Thanks, as I wrote the autobox shift is stuck in the manual gate position and i cant get it to move across to the D position. Correct me if I am wrong but the link you posted was for the shift being stuck in the park position, and you can move it out of this position with the shift lock button, mine is stuck in the manual side of the box but with no gears engaged. Can someone tell me if when you move the shifter across from A to manual mode as it crosses the gate is their any movement felt from the shifter ie-you feel it slightly raise up or down etc???? Thanks Just checked mine - there is an initial slight resistance and then it just pops straight across - no up or down movement. Quote Link to comment Share on other sites More sharing options...
Zazur Posted March 18, 2009 Author Share Posted March 18, 2009 Just checked mine - there is an initial slight resistance and then it just pops straight across - no up or down movement. Thanks Jim, Sounds like I have something come adrift, broken or lose in the shifter as it went straight into the manual mode and seemed to skip the D mode if I remember when it happened. I removed the surrond but could not remove the gear nob or the P,R,N,D plastic cover so could not see into the mechanism but I could see the metal bar which runs through the shifter moving up and down ok when the side button is pushed, not sure if it should be attached to something to push,pull,lift or lower anything as it is quite a long bar to be doing nothing. Does anyone know if that bar is attached to anything??? Quote Link to comment Share on other sites More sharing options...
marzman Posted March 18, 2009 Share Posted March 18, 2009 But what my link did say is that the solenoid can break... i would think this could happen at any time... not just while in a certain gear position etc? Not helpful i know but needs considering. Quote Link to comment Share on other sites More sharing options...
marzman Posted March 18, 2009 Share Posted March 18, 2009 Download the 350z service manual here: http://www.350z-uk.com/forum/viewtopic.php?t=2945 Look in the AT section - lots of useful (if complicated) info in here... Quote Link to comment Share on other sites More sharing options...
Zazur Posted March 20, 2009 Author Share Posted March 20, 2009 Downloaded the US service manual but still could not find what the problem was so today arranged a truck to pick the Z up and take it to a garage in Italy, hopefully to be repaired. Thanks guy's for all your input with my problem Quote Link to comment Share on other sites More sharing options...
marzman Posted March 20, 2009 Share Posted March 20, 2009 Good look bud - hopefully wont be to expensive for you. Please keep us posted on it... Quote Link to comment Share on other sites More sharing options...
Zazur Posted March 21, 2009 Author Share Posted March 21, 2009 Good look bud - hopefully wont be to expensive for you. Please keep us posted on it... Car was delivered back to me today all fixed. A bit of plastic in the shifter mechanism had come adrift and one of the sensors was also playing up when they put it on the computer, deceided not to give it to a Nissan garage as not many Z's over here and I always had problems whenever my Lexus was serviced so it went to a small garage and it took them 3 hours to fix . So life is good again Quote Link to comment Share on other sites More sharing options...
Maccaman Posted March 21, 2009 Share Posted March 21, 2009 Great result I bet that was a great relief. Quote Link to comment Share on other sites More sharing options...
marzman Posted March 21, 2009 Share Posted March 21, 2009 Oh my god, how lucky are you?? Result!! Quote Link to comment Share on other sites More sharing options...
jim Posted March 21, 2009 Share Posted March 21, 2009 Great stuff - glad it all worked out well. Quote Link to comment Share on other sites More sharing options...
Zazur Posted March 22, 2009 Author Share Posted March 22, 2009 Thanks guys Yes it was a huge relief to find it was something easy to fix Quote Link to comment Share on other sites More sharing options...
