20mm Eibach Pro Spacers - 2 Sets
redzed
  CS said:
No issues at all with having 20mm front and rear, the only difference is the system, these are system 6, using longer studs... :thumbs:
Is that the type where you have to drill out your old studs to fit them?
  jerry3167 said:
:) Hi m8,
I take it these are for the FRONT at 20mm, so 25mm WOULD BE REQUIRED for the rear?
Jerry :)
You should have the same front and rear, or you`re not aligning the wheels correctly.
There`s no drilling required these fit straight on.
  jerry3167 said:
Whats with the longer studs?
You need longer studs to go through the spacer and the wheel. a much better system than stud extensions.
  Squarehead said:
And why should you have 20mm all round? The rear tyres are wider so alignment shouldn't be affected?
Of course it`s affected! If you put extra width on the rear, your rears are not following the fronts as the manufacturer intended. Basic maths.
