Zazur Posted March 13, 2009 Share Posted March 13, 2009 Hi, It has began to warm up a little bit over here at last and today after some heavy braking down a long hill the peddle and car began to judder quite badly and dissapeared after a period of normal driving. I guess I will have to and replace the brakes. I have non brembo brakes (2003 US model). What discs and pads would you advise for me and where is the place to get them from. Thanks Quote Link to comment Share on other sites More sharing options...
MITZ@CougarStore Posted March 13, 2009 Share Posted March 13, 2009 Hi, quite a few disc options for the import, EBC standard and Turbo Groove and also DBA too. Pads are also available from EBC in the Import fitment to, happy to help with this, if you know for sure that they do need replacing... Quote Link to comment Share on other sites More sharing options...
sunset350z Posted March 13, 2009 Share Posted March 13, 2009 Depends on how much you want to spend, give Envy or CS a ring. If you fancy swapping to Brembo's, Zmanalex is the man to see . I've got some goodridge stainless steel brake hoses you can have for 55 quid delivered, that will help with your braking as well. Quote Link to comment Share on other sites More sharing options...
Zazur Posted March 13, 2009 Author Share Posted March 13, 2009 CS said: Hi, quite a few disc options for the import, EBC standard and Turbo Groove and also DBA too. Pads are also available from EBC in the Import fitment to, happy to help with this, if you know for sure that they do need replacing... Do you know what could be causing the vibration? I assumed (I know you should not assume) it was due to the disc thickness warping Please advise Quote Link to comment Share on other sites More sharing options...
sunset350z Posted March 13, 2009 Share Posted March 13, 2009 Overheating would be a likely cause, due to worn pads and discs imo. Quote Link to comment Share on other sites More sharing options...
MITZ@CougarStore Posted March 13, 2009 Share Posted March 13, 2009 Zazur said: CS said: Hi, quite a few disc options for the import, EBC standard and Turbo Groove and also DBA too. Pads are also available from EBC in the Import fitment to, happy to help with this, if you know for sure that they do need replacing... Do you know what could be causing the vibration? I assumed (I know you should not assume) it was due to the disc thickness warping Please advise If the discs and pads are quite old/worn they won't be used to the hard braking style you were doing... As you said, once 'normal' braking was resumed all appears to be well. How worn are your discs, do you have a lip forming on the outer edge... Quote Link to comment Share on other sites More sharing options...
Zazur Posted March 13, 2009 Author Share Posted March 13, 2009 If the discs and pads are quite old/worn they won't be used to the hard braking style you were doing... As you said, once 'normal' braking was resumed all appears to be well. How worn are your discs, do you have a lip forming on the outer edge... The discs have no lip on them, I guess they could be the orginal discs as the car has only done 26K since new but the car is 2003 model so quite old. Comments please Quote Link to comment Share on other sites More sharing options...
sunset350z Posted March 14, 2009 Share Posted March 14, 2009 The discs and pads will degrade with age as well, so being that old will definitely need replacing before you have a total failure. Quote Link to comment Share on other sites More sharing options...
Zazur Posted March 14, 2009 Author Share Posted March 14, 2009 Thanks, Where's the best place to source discs and pads and what do you think would be the best set for me to use here in the temps of the South of France summers? Quote Link to comment Share on other sites More sharing options...
MITZ@CougarStore Posted March 14, 2009 Share Posted March 14, 2009 Zazur said: Thanks,Where's the best place to source discs and pads and what do you think would be the best set for me to use here in the temps of the South of France summers? How will you be using you car, would you ever be going on track or would it just be day to day driving... Quote Link to comment Share on other sites More sharing options...
Zazur Posted March 14, 2009 Author Share Posted March 14, 2009 CS said: Zazur said: Thanks,Where's the best place to source discs and pads and what do you think would be the best set for me to use here in the temps of the South of France summers? How will you be using you car, would you ever be going on track or would it just be day to day driving... Unlikely I will do any track driving, so I will say mostly normal road use with some possible heavy braking times. Quote Link to comment Share on other sites More sharing options...
Chris`I Posted March 14, 2009 Share Posted March 14, 2009 Sounds like a perfect oppotunity to try the Ferrodo DS pads. A lot of guys on here (myself included) use the DS2500 which are fast road/track pads. The DS are the more street oriented pads. Quote Link to comment Share on other sites More sharing options...
MITZ@CougarStore Posted March 14, 2009 Share Posted March 14, 2009 Chris`I said: Sounds like a perfect oppotunity to try the Ferrodo DS pads. A lot of guys on here (myself included) use the DS2500 which are fast road/track pads. The DS are the more street oriented pads. Chris, the DS are currently only in the Brembo fitment but I do have a few options for the Import caliper... Quote Link to comment Share on other sites More sharing options...
Chris`I Posted March 15, 2009 Share Posted March 15, 2009 CS said: Chris`I said: Sounds like a perfect oppotunity to try the Ferrodo DS pads. A lot of guys on here (myself included) use the DS2500 which are fast road/track pads. The DS are the more street oriented pads. Chris, the DS are currently only in the Brembo fitment but I do have a few options for the Import caliper... Quote Link to comment Share on other sites More sharing options...
