Burning smell + Heat from passenger front brake
Hey guys was driving to the fuel station tonight (as I tend to do alot) and had this strange smell like burning rubber suddenly in the cabin, thought nothing of it as it cleared after a few mins, but as I was at the petrol station I decided to check the tyre pressures.
Well went to the driver's front wheel checked the pressure, then went to the passenger side wheel and immediately felt the heat coming from the brake and the smell that I had smelt in the cabin before.
Kinda worried now that there is something jammed on/in the passenger brake.
Any one any idea's what could be causing this?
Cheers
Sounds like a seized caliper mate
Had similar thing happen to me in my MR2, to the extent that the friction caused the whole alloy to heat up, very hot!
Its just a case of refurbing the caliper, which i managed to do myself, with the help of youtube clips!
OR a new caliper...
It might be the issue anyway....
Ok update, Drove into work this morning and then checked the temp on both front brakes and it seems that both were normal, no bad smell and no excessive heat from the passenger side.
Maybe the caliper has unstuck itself?!
Will keep an eye on it and see if it happens again.
Cheers guys
