Spill Posted May 26, 2006 Share Posted May 26, 2006 Eventually got round to sorting this and thought it may be interest . Due to the success of sponsoring pickup truck no.88 last year we decided to go one stage further and sponsor the team. First launched in 1997, the Pickup series is for purpose built 230bhp racing specials. A tubular spaceframe chassis follows well-proven SHP Motorsport principles and the racers are pushed along by a 2 litre multi-valve twin-cam engine. Weighing in at just 900kg, these dramatic machines place the emphasis firmly on driver ability. The engines are badged as a PickupSport engine comprising of 4 cylinder 16 valve unit with 86 mm bore 86mm stroke Fitted with modified cylinder head,which in turn is fitted with 33mm inlet valves, 29mm exhaust forged piston and a maximum compression ratio of twelve to one. Steel conrods are used, the rest of the bottom end is stock with the exception of a steel fly wheel. The engine uses a wet sump oil system. Carburation is via twin 48 DCOE with 40mm chokes. The ignition system is a controlled unit by MBE with maximum rev limiter set at 7500, this gives a power output of 229 BHP with 170 ft / lbs of torque. The series consists of 20 rounds with 26 drivers on the starting grid with Rockingham playing host to the first two rounds on 7th May We came a respectable 10th and 8th It makes a great day out with a packed race programme, they have open garages so fans can see exactly what's happening and kids get in free @ Rockingham, Remaining rounds 3rd / 4th June, Croft 24th / 25th June, Rockingham (oval) 8th / 9th July, Rockingham (oval) 12th / 13th August, Rockingham (oval) 19th / 20th August, Brands Hatch (Indy) 9th / 10th September, Rockingham, (oval) 23rd / 24th September, Snetterton 7th / 8th October, Rockingham (oval) 4th / 5th November, Brands Hatch (Indy) njoy Quote Link to comment Share on other sites More sharing options...
Removed Posted May 26, 2006 Share Posted May 26, 2006 cool! saw some pickup trucks action @ Rockingham some time ago, they were cool! Quote Link to comment Share on other sites More sharing options...
Nick_MSM Posted May 26, 2006 Share Posted May 26, 2006 Looks great fun, best of luck with it. Quote Link to comment Share on other sites More sharing options...
