jim Posted March 12, 2009 Share Posted March 12, 2009 I got a new set of hoses recenty but not yet got round to fitting them. Is it difficult? Is the radiator drain tap easy to access? Cheers in advance for any advice offered. Quote Link to comment Share on other sites More sharing options...
jim Posted March 13, 2009 Author Share Posted March 13, 2009 BUMP! Nobody got any advice? Quote Link to comment Share on other sites More sharing options...
Jay Posted March 13, 2009 Share Posted March 13, 2009 BUMP! Nobody got any advice? Dont do drugs (sorry jim couldnt help it ) Thats what happens when am in uni 9 - 3 Quote Link to comment Share on other sites More sharing options...
3FIDDYZ Posted March 13, 2009 Share Posted March 13, 2009 I did mine with out draining..... was just quick!!! Quote Link to comment Share on other sites More sharing options...
dcash5 Posted March 13, 2009 Share Posted March 13, 2009 I did mine with out draining..... was just quick!!! yes but didnt ur car then loose all power whilst doing 80mph down the motorway? Quote Link to comment Share on other sites More sharing options...
3FIDDYZ Posted March 13, 2009 Share Posted March 13, 2009 Hmmmmmm...... yes, forgot about the airlock!!! Just needed to top up the coolant! Just need to locate the air lock valve when you refit and squeeze the pipes to get rid of any air!! Quote Link to comment Share on other sites More sharing options...
jim Posted March 13, 2009 Author Share Posted March 13, 2009 BUMP! Nobody got any advice? Dont do drugs (sorry jim couldnt help it ) Thats what happens when am in uni 9 - 3 Coming from a student, that's really good advice! Quote Link to comment Share on other sites More sharing options...
jim Posted March 13, 2009 Author Share Posted March 13, 2009 Hmmmmmm...... yes, forgot about the airlock!!! Just needed to top up the coolant! Just need to locate the air lock valve when you refit and squeeze the pipes to get rid of any air!! The top hose should not lose too much fluid but the other one might cause a bit of leakage uness you're really quick! I'll have a go at the weekend. Thanks for the suggestion. Any idea where the air lock valve is? Quote Link to comment Share on other sites More sharing options...
sunset350z Posted March 13, 2009 Share Posted March 13, 2009 I'm sure once you've changed the hoses, you can just let the engine run on idle, leave the rad cap off, and top up with coolant. All the air bubbles will escape through the open rad that way. Give the bottom hose a sqeeze a few times as well. Quote Link to comment Share on other sites More sharing options...
jim Posted March 13, 2009 Author Share Posted March 13, 2009 I'm sure once you've changed the hoses, you can just let the engine run on idle, leave the rad cap off, and top up with coolant. All the air bubbles will escape through the open rad that way. Give the bottom hose a sqeeze a few times as well. Thanks for that. What coolant do you recommend for topping up - do you use Nissan's own? Quote Link to comment Share on other sites More sharing options...
sunset350z Posted March 13, 2009 Share Posted March 13, 2009 Yes, if your car has been serviced with nissan then top up with nissan's own brand. Quote Link to comment Share on other sites More sharing options...
sunset350z Posted March 13, 2009 Share Posted March 13, 2009 Just bought some coolant from nissan when i picked up my throttle body gasket, it was just over 4 quid for a litre, bargain Quote Link to comment Share on other sites More sharing options...
