Best way to cut Samco Superflex Hose???
SteveW
Morning chaps,
I'm wondering if you can help me, does anyone know the best way to cut Samco superflex hose (th eone with the metal wire in it) I can cut it but the neds look a right mess with the wire merrily poking out.
I've been using a Stanley and a Hacksaw which isn't a good idea.
Any help appreciated.
Thanks
Steve
How far in is the metal braid? I'd be tempted to cut the outer silicone with something sharpe like a Stanley blade and then cut through the rest with a dremmel. Keeps the outer edges nice and neat then as they're the only ones you'll see :)
Thanks guys, I'd not thought of trying the Dremel.
The superflex stuff has a 2mm single wire braid which is coiled like a spring and then the silicone is formed over the top of it.
Generally you only need to cut through one coil per cut which isn't too bad.
The braid isn't to increase burst pressure as such but to stop the hose collapsing when you bend it at angles. I'm using it on emy track car cos all the coolant hoses need replacing and OE ones are ridiculous prices!!!!
Thanks
