Head unit change with InCarTec Adapter
Fergin
Hi
I am about to install a new head unit in my 350z (Bose system)
I have purchased an incartec adapter which has connection for RCA pre outs, The stereo I am putting in has facillity for bot front and back preouts.
My question is on this adapter there is Amp on (Blue/white) & Earth (Black/white) from plug which goes to car harness. Does this need connecting to power on from stereo (same colour wire), I am abit confused how the preouts integrate with amp in car and stereo
Any help much appreaciated
Thanks
Fergin
The amp on one needs to be connected to the blue/white wire coming from the new headunit. This will fire up the bose amp when the stereo powers up.
You must ground the unit well to the chassis otherwise it will not work correctly.
Hope this helps
Ross :D
Thanks Guys
Will sort some pics when time allows,
Actual zed is better halfs car pretty standard apart from scorpion exhaust. I've got an impreza sti (but dont hold that against me), maybe I should get her posting on here!!!!!!!!!
Cheers
Fergin
