Zee Posted March 2, 2009 Share Posted March 2, 2009 Hey Guys I had new Discs and Pads fitted last week and over the weekend i washed my car paying particular attention to the alloys using a lot of water to get them clean. Now i've noticed that when braking the brakes Squeal but this only happens under very slow speed, usually under 10mph. Should i take the car back and get them checked out or are they still damp from washing it? tia Quote Link to comment Share on other sites More sharing options...
Chris`I Posted March 2, 2009 Share Posted March 2, 2009 What discs and pads have you had fitted? Usually with high performance pads its because they need bedding in properly. There are links to a few guides on here if you do a search. Quote Link to comment Share on other sites More sharing options...
MITZ@CougarStore Posted March 2, 2009 Share Posted March 2, 2009 If you used a pressure washer etc it might also be a case of washing off part of the copper grease whilst you were cleaning your wheels, you may need to take the pads out and apply copper grease again, this could remedy the squeal… Quote Link to comment Share on other sites More sharing options...
Chris`I Posted March 2, 2009 Share Posted March 2, 2009 If you used a pressure washer etc it might also be a case of washing off part of the copper grease whilst you were cleaning your wheels, you may need to take the pads out and apply copper grease again, this could remedy the squeal… Just re-read the OP post and you might be right. Would have thought it would take a bit of effort to blast out the copper grease though Did this happen since they were fitted or only since they were washed? Quote Link to comment Share on other sites More sharing options...
herbie Posted March 2, 2009 Share Posted March 2, 2009 Yeah I'd take the car back to get everything greased up again as the squealing noise wont dissapear on its own Quote Link to comment Share on other sites More sharing options...
Zee Posted March 2, 2009 Author Share Posted March 2, 2009 I think the noise occured since they were washed. Quote Link to comment Share on other sites More sharing options...
M13KYF Posted March 2, 2009 Share Posted March 2, 2009 re cooper grease and perhaps re perform the bedding in procedure for good measures Quote Link to comment Share on other sites More sharing options...
Zee Posted March 2, 2009 Author Share Posted March 2, 2009 Typical, I booked it into the garage this afternoon to be looked at on Thursday and when i drove home from work this afternoon the brakes are no longer squealing! Ha Ha its like they know!! Maybe they were still damp from the uber wash session? Quote Link to comment Share on other sites More sharing options...
matth76 Posted March 6, 2009 Share Posted March 6, 2009 Mine squeal very slightly when it has been a wet night, and more often when reversing and only when going slowly. Normal braking doesn't cause any noise. Quote Link to comment Share on other sites More sharing options...
ledzed Posted March 20, 2009 Share Posted March 20, 2009 Hi guys,had my zed for about a week and my rear brakes have started squeaking.They are brembos and it's a VERY annoying pulsating squeak.The squeaking disappears when i pull handbrake up/normally brake.I've taken the pads out(half worn ish) and copper greased between the metal plate and the back of the pad side.It did nothing.Any suggestions?? Any help most welcome.PS car has only done 8k miles. Quote Link to comment Share on other sites More sharing options...
M13KYF Posted March 23, 2009 Share Posted March 23, 2009 Hi guys,had my zed for about a week and my rear brakes have started squeaking.They are brembos and it's a VERY annoying pulsating squeak.The squeaking disappears when i pull handbrake up/normally brake.I've taken the pads out(half worn ish) and copper greased between the metal plate and the back of the pad side.It did nothing.Any suggestions?? Any help most welcome.PS car has only done 8k miles. whats the condition of the discs. If they are quite worn they can begin to make a squeal if there is a considerable lip Quote Link to comment Share on other sites More sharing options...
ledzed Posted March 28, 2009 Share Posted March 28, 2009 whats the condition of the discs. If they are quite worn they can begin to make a squeal if there is a considerable lip The discs are like new.Typically the noise has stopped since i moaned about it but i have ordered a set of red stuff brake pads to hopefully stop it from coming back. Quote Link to comment Share on other sites More sharing options...
