OIL PRESSURE?????
vasser
Thanks Trev.
Just put fresh oil in the car and the pressure was really high. Took it out for a little run and had to brake quite heavily and the pressure levels have returned to normal. Maybe and air bubble trapped or something. seems to be sorted now, did use the thin oil though CASTROL 5W. dont quite understand what happened
Thanks again :thumbs:
Thanks Trev.
Fresh cold oil = higher oil pressure....
Also depends on what make of oil filter you used, that is if you changed it which I hope you did ;)
