R800NER Posted February 14, 2009 Share Posted February 14, 2009 Everytime I bring my new zed back to the house, there is a strong smell of burning plastic, quite a horrid smell which I am led to believe could be the clutch going? Is this going to be an expensive fix? Quote Link to comment Share on other sites More sharing options...
martinmac Posted February 14, 2009 Share Posted February 14, 2009 If its your clutch I would recommend you sorting it soon or you will need a new flywheel too. Worth considering upgrading. Quote Link to comment Share on other sites More sharing options...
R800NER Posted February 14, 2009 Author Share Posted February 14, 2009 Sorry I don't quite understand the mechanics behind the flywheel getting damaged too? Is there a simple explanation for it? I haven't driven it hard or ridden the clutch, even a trip round the block leaves a rather pungent smell....Clutch hasn't slipped as far as I am aware... How much would a new clutch cost inc fitting as a ballpark? Quote Link to comment Share on other sites More sharing options...
Trev-the-Rev Posted February 14, 2009 Share Posted February 14, 2009 Put it in 4th gear and floor it around 2000 rpm if the clutch doesn't slip then your problem is elsewhere. Quote Link to comment Share on other sites More sharing options...
Stew Posted February 14, 2009 Share Posted February 14, 2009 Never smelt a burning plastic smell...... Have you checked that nothing cold is hitting something hot like the manifold..... Quote Link to comment Share on other sites More sharing options...
Chris`I Posted February 14, 2009 Share Posted February 14, 2009 Sounds to me that something plastic is hitting something hot rather than the clutch if the clutch isnt slipping. Have a look underneath and make sure there isnt a platic bag stuck to some of the exhaust or something. Quote Link to comment Share on other sites More sharing options...
R800NER Posted February 14, 2009 Author Share Posted February 14, 2009 hmmm right I did the old handbrake and pull away with clutch trick and it stalled and clutch seems fine. It is definately a smell on the drivers side behind the wheel arch... which side does the exhaust run down? I am thinking it could be exhaust related. I will get it up on the ramps and have a look. Quote Link to comment Share on other sites More sharing options...
Stew Posted February 14, 2009 Share Posted February 14, 2009 which side does the exhaust run down? I am thinking it could be exhaust related. . Think about it........ Penny dropped yet? Quote Link to comment Share on other sites More sharing options...
Stew Posted February 14, 2009 Share Posted February 14, 2009 Here's a clue.... Quote Link to comment Share on other sites More sharing options...
Stew Posted February 14, 2009 Share Posted February 14, 2009 though it does have an aftermarket exhaust but you get the jisy. On the standard exhaust the the pipes join after the cats (goldy boxes in the pic) at the Y pipe then it's one pipe the the backbox. Quote Link to comment Share on other sites More sharing options...
Beavis Posted February 14, 2009 Share Posted February 14, 2009 Could even be an electrical burning smell Quote Link to comment Share on other sites More sharing options...
R800NER Posted February 14, 2009 Author Share Posted February 14, 2009 Sorry for being a numpty, I have limited technical knowledge! I had thought that the exhaust split into two at the backbox... but then I am a noobie! Hmmm, so what's the best way of figuring this out?? Electrical? Is there a specialist that could tell me? or a member? Quote Link to comment Share on other sites More sharing options...
Stew Posted February 14, 2009 Share Posted February 14, 2009 Sorry for being a numpty, I have limited technical knowledge! I had thought that the exhaust split into two at the backbox... but then I am a noobie! Hmmm, so what's the best way of figuring this out?? Electrical? Is there a specialist that could tell me? or a member? Sorry, was for my own amusement. Being a V6 there are two exhaust manifolds but on the standard exhaust they do join after the cats. Maybe see if there is an owner based locally that might help out. If not I'd take it to a garage to be honest. Quote Link to comment Share on other sites More sharing options...
ZMANALEX Posted February 14, 2009 Share Posted February 14, 2009 It is definately a smell on the drivers side behind the wheel arch... . o/s/r/ brake binding on slightly ????? Nothing else in that area that would give off a pong. Dead rat ???? Quote Link to comment Share on other sites More sharing options...
mc Posted February 16, 2009 Share Posted February 16, 2009 Mine quite often smells 'hot' if you know what I mean lol... not like burning plastic which is quite pungent, but something maybe like rubber although I can't find anything under the bonnet, it has done it for a while now Quote Link to comment Share on other sites More sharing options...
Ebized Posted February 16, 2009 Share Posted February 16, 2009 Sniff this out http://www.350z-uk.com/forum/viewtopic ... rnt+bumper Quote Link to comment Share on other sites More sharing options...
WoREoD Posted February 17, 2009 Share Posted February 17, 2009 I had this on a car once. Turned out I'd picked up one of those supermarket carrier bags that blow around our roads and it was snagged on an exhaust clip and melting onto the hot exhaust. Quite difficult to remove once they've started to melt...... Quote Link to comment Share on other sites More sharing options...
mc Posted February 17, 2009 Share Posted February 17, 2009 well my 50 mile commute home last night didn't cause any funny smells (from the car!) I'm thinking that the plastic bag theory could be what caused it, will have to see if it happens again. Thanks for the link Ebized, my exhaust needs re-hanging as its slightly higher on one side and virtually touches the bumper. Quote Link to comment Share on other sites More sharing options...
manc350z Posted February 18, 2009 Share Posted February 18, 2009 Mine can sometimes smell like burning clutch / brakes etc.. but only after spirited driving and late .. ahem.. braking / accidental drifting.. :0) ..quite normal.. Quote Link to comment Share on other sites More sharing options...
Jammy007 Posted February 18, 2009 Share Posted February 18, 2009 On my FTO I had a burning smell coming from the car, was very noticeable once getting out of the car after a run. Looked underneath and there was something plastic (probably a carrier bag) stuck to my mongoose. Took a bit of scraping to get it off there but made me feel 10 times better once I'd actually realised what it was. Get on your hands and knees and have a good look! Can't do any harm if you don't touch anything, thats my motto! Quote Link to comment Share on other sites More sharing options...
IanS16 Posted February 18, 2009 Share Posted February 18, 2009 I had a hole in the flexi pipe on my Y pipe so whenever I stood still for over 10 seconds the exhaust fumes would come up over the sides of the car. It didn't smell like the fumes coming out of the exit pipes, it smelled more like burning but it went when I had my Y pip fixed. Quote Link to comment Share on other sites More sharing options...
