*Please Help* PAC/ Kenwood/Bose Integration!!!!!!!!!
Nordic GT
Hi all, I wonder if someone can help.
I have a UK GT with Bose however the uk Bose was replaced with a JAP Bose before I got it which was doing my head in when cold.
I had my Kenwood headunit still in the old car so decided to swap it over.
I purchased the single din dash
PAC NIS1 (I believe) says OEM 1
Kenwood lead from headunit to pac
Firstly after taking out the Bose head unit I discovered that there is just endless adaptors for presumably the bose system.That end up in a box in below the passenger airbag.
Well I soldered the new kenwood adaptor tails to the pac and once finished belled them out to check continuity all was well.
There are cables not attached as follows:
Kenwood lead: Power Antenna, Phone mute
PAC: Power Antenna
When I connect it all up there is no sound through the speakers.Having done a few basic installs in my previous car this points to the switch wire for the amp however this seems to be working.
All the wiring seems to be fine so extremely confused.
Any ideas welcome and will be much appreciated.
Also reading one of the latest posts can someone confirm that the pac adaptor should work without the steering control.
Also is it better to get the ICT leads and adaptor, and confirm it is just the two leads that are required and no PAC is required.
Your help is greatly appreciated.
Cheers Dave
