SteveW Posted February 9, 2009 Share Posted February 9, 2009 Good evening all, I'm hoping to go on my first trackday at the end of the month and need some new brakes, pads are getting quite low and the rear discs look to be getting a bit thin - still without run out limits on a clock but worn to around 2mm depth. My question is do I go for standard discs or EBC turbogrooves? Also which pads should I go for? Standard, red stuff or yellow stuff? I want some pads that will still be good on the work day commute and not cause me any oh @*!# moments can't stop....... I've seen the good prices CS offers on the EBC pads. Any info anyone can offer will be very much appreciated. If it makes any difference Donnington Park is the venue. Steve Quote Link to comment Share on other sites More sharing options...
MITZ@CougarStore Posted February 9, 2009 Share Posted February 9, 2009 Steve, for track day pads I'd go with Ferodo DS2500, they work well on the track and are also suitable for day to day driving... You can marry these up with the EBC Turbogroove discs, they'll work perfectly together... EBC Yellowstuff pads can also be used on Track, however, the DS2500 can take more harder braking and punishment... Quote Link to comment Share on other sites More sharing options...
Chris`I Posted February 9, 2009 Share Posted February 9, 2009 Steve, for track day pads I'd go with Ferodo DS2500, they work well on the track and are also suitable for day to day driving... You can marry these up with the EBC Turbogroove discs, they'll work perfectly together... EBC Yellowstuff pads can also be used on Track, however, the DS2500 can take more harder braking and punishment... +1 to the above. I have that exact combo (EBC Turbo grooved and DS2500) and they are very much noticably better than stock. Although I have never tracked my car, the pads can take a serious beating, much more than stock. You wont be dissapointed Quote Link to comment Share on other sites More sharing options...
SteveW Posted February 9, 2009 Author Share Posted February 9, 2009 Replies on this forum are Like lightening!!! excellent!! Do the DS2500 still work well when they are cold? I spend most of my time on the day to day commute and obviously don't want any I can't stop moments!!! So a set up which works on track and on the street is what I'm after. Thank you Quote Link to comment Share on other sites More sharing options...
MITZ@CougarStore Posted February 9, 2009 Share Posted February 9, 2009 The DS2500 always work better after a few applications, once they heat up they’re amazing, the stopping power is quite immense… The Yellowstuff pads wouldn't require the same, they're almost good to go from the off for road use... Quote Link to comment Share on other sites More sharing options...
Martin W Posted February 9, 2009 Share Posted February 9, 2009 Replies on this forum are Like lightening!!! excellent!! Do the DS2500 still work well when they are cold? I spend most of my time on the day to day commute and obviously don't want any I can't stop moments!!! So a set up which works on track and on the street is what I'm after. Thank you Well, you wouldn't possibly be going that fast on the commute would you Seriously, I do the same, they are fine even when cold in my experience. Quote Link to comment Share on other sites More sharing options...
SteveW Posted February 9, 2009 Author Share Posted February 9, 2009 Not quite going trackday fast on the day to day commute Thank you for the info saying that the DS2500's are all good from cold thats always good news when things go pear shaped... Thank you Quote Link to comment Share on other sites More sharing options...
Maccaman Posted February 9, 2009 Share Posted February 9, 2009 I changed mine for the DS2500 quite recently and I've found them to be excellent. Much better than standard. Quote Link to comment Share on other sites More sharing options...
Chris`I Posted February 9, 2009 Share Posted February 9, 2009 I'd say that the cold bite isnt the best it could be, maybe a bit worse than stardard pads, but it only takes a few applications to get some heat into them, and tbh its quite hard to notice. Making sure you break them in properly is the main thing to getting good performance from them. Quote Link to comment Share on other sites More sharing options...
MrLizard Posted February 10, 2009 Share Posted February 10, 2009 I'd say that the cold bite isnt the best it could be, maybe a bit worse than stardard pads, but it only takes a few applications to get some heat into them, and tbh its quite hard to notice. Making sure you break them in properly is the main thing to getting good performance from them. +1 ive tried the yellow stuff and the ferodo's, for daily use they are very similar, maybe slightly more bite from cold in the yellow stuff, and for track use the DS2500's are far better imo assuming your lapping a track and not doing sprints. Quote Link to comment Share on other sites More sharing options...
lotuscc Posted February 10, 2009 Share Posted February 10, 2009 Yellowstuff work well when cold and hot on the road. They are used in one of the motorsport formulas and so are great for the track too. They do not squeal like the DS2500s potentially can. Quote Link to comment Share on other sites More sharing options...
Stew Posted February 10, 2009 Share Posted February 10, 2009 Dixcel??????? Quote Link to comment Share on other sites More sharing options...
SteveW Posted February 11, 2009 Author Share Posted February 11, 2009 Thanks for the information guys very good info. I've heard of Dixcel stuff but thought it was only available from the US? Has anyone ever used Carbotechs? My mate has them on his MR2Turbo and swears they are the best brakes he has ever had. Quote Link to comment Share on other sites More sharing options...
Chris`I Posted February 11, 2009 Share Posted February 11, 2009 Has anyone ever used Carbotechs? My mate has them on his MR2Turbo and swears they are the best brakes he has ever had. The Evo chaps use them alot. But if you thought DS2500 squeal a lot, you gotta hear the Carbotechs! Christ, they are never quiet at any speed! Quote Link to comment Share on other sites More sharing options...
Stew Posted February 12, 2009 Share Posted February 12, 2009 Thanks for the information guys very good info. I've heard of Dixcel stuff but thought it was only available from the US? Has anyone ever used Carbotechs? My mate has them on his MR2Turbo and swears they are the best brakes he has ever had. Dixcel is available from DMS and they happen to be a site sponsor. Their user name is DixcelBrake. Myself and AdrianK have dixcel setups. I'm certainly very pleased with mine. Hasn't been tracked yet but Dixon (DMS proprietor) reckons they will be even better on the track. Quote Link to comment Share on other sites More sharing options...
IanS Posted February 12, 2009 Share Posted February 12, 2009 Having discussed this at lenth with BigPhil on the phone before Christmas, I decided to go with Performance Frication pads on DBA disks. Not the cheapest, but very pleased with them so far. Have not experienced any squeeling from the pads - used to get some from EBC. While you are at it, some stainless lines are a must Quote Link to comment Share on other sites More sharing options...
M13KYF Posted February 12, 2009 Share Posted February 12, 2009 another one to consider for track day use is liek sarnie said Dixcel Brakes http://www.350z-uk.com/forum/viewtopic ... 67&start=0 Quote Link to comment Share on other sites More sharing options...
