richnottm Posted February 8, 2009 Share Posted February 8, 2009 Hi..ive got a 2005 z fitted with standard Brembos. Total mileage about 33k..If have a recurring problem where first thing in the morning when moving off the brakes stick badly. I need to rev the engine a bit to get the car moving then all is fine. I left the car standing for 2 weeks (when we had the bad snow) and moving the brakes had seized a lot. Now I see the osr pad has moved and the brakes vibrate when i apply them. I have booked car in for new pads all round BUT what my question is: is there a design fault with these Brembos??..thanks guys Quote Link to comment Share on other sites More sharing options...
Lexx Posted February 8, 2009 Share Posted February 8, 2009 pads normally stick when the discs have rusted. Its possible your discs are shot and in need of replacing, so corroding/rusting pretty quickly overnight and causing the pads to stick Quote Link to comment Share on other sites More sharing options...
GIXXERUK Posted February 8, 2009 Share Posted February 8, 2009 this is normal, all cars do it to varying degrees all discs rust as they are bare metal and will oxidise from the moisture in the air, obviously worse in winter or summer when you wash the car Quote Link to comment Share on other sites More sharing options...
martinmac Posted February 8, 2009 Share Posted February 8, 2009 As Gix says, I have to leave my car stationary for a few weeks at a time and they normally require unsticking. Quote Link to comment Share on other sites More sharing options...
Chris`I Posted February 8, 2009 Share Posted February 8, 2009 Does the vibration change at varying speeds? I.e. vibrate a lot at speed and slower as the pace slows? Have you been out for a spirited drive and then come to a hault with the brakes fully appied? It sounds to me like you have 2 problems. One is the normal brakes rusting which is fine. The second is that you have imprinted some pad material onto the disks which gives you the judder. You can get it skimmed off the disk or try breaking in the pads again and hope to get it off. Quote Link to comment Share on other sites More sharing options...
M13KYF Posted February 8, 2009 Share Posted February 8, 2009 +1 Quote Link to comment Share on other sites More sharing options...
richnottm Posted February 8, 2009 Author Share Posted February 8, 2009 thx guys..hopefully new set of pads will resolve problem (to some degree) Quote Link to comment Share on other sites More sharing options...
Rentech Posted February 13, 2009 Share Posted February 13, 2009 Had this problem with the my last few cars. Think my problem is amplified with the fact that I have to park on a hill, requiring more hand brake to hold. As previously mentioned, moisture seems to increase the problem. If I forget (or don't have time) to take the car for a spin, after washing the car, it can really 'clonk' as the brakes free up from the discs. Not sure if new brake disks will help, just a trait. Quote Link to comment Share on other sites More sharing options...
DavidS14 Posted February 13, 2009 Share Posted February 13, 2009 From another thread with the same kind of problem You can get this type of affect with certain pads when the car has been parked for a while, depending on the binders and additives in the friction material. If the pad is in contact with a section of the disc for a long period you can get a surface reaction between the friction material and the rotor surface. This is accelerated if there is an electrolytic solution present (salt water this time of year) and can lead to a deposit being left on the disc when the car is moved. On your first brake application you then hear/feel a slight vibration as the friction material of the pad encounters the deposit on each revolution of the rotor until it's removed. An easy way to check for this is next time you leave the car for a while just move it forward about a foot and then have a look at the brake disks. You should be able to see the area of the rotor that the pad was in contact with whilst it was parked. I have R34 brembos on my 200 and if it's parked for a few days I get the same thing on my first brake application (that's with DS2500 pads) and if I check the rotors I can see the outline of the pads on the surface. Quote Link to comment Share on other sites More sharing options...
Chris`I Posted February 13, 2009 Share Posted February 13, 2009 Just leave it in gear with no hand brake. Thats what I do now, no more pad prints Quote Link to comment Share on other sites More sharing options...
