MITZ@CougarStore Posted February 4, 2009 Share Posted February 4, 2009 All, thought I should mention that I also have the EBC Ultimax discs available in the Brembo fitment only, for a front and rear set delivered £370.00 They start off looking like this… And after a few applications they look this As always, if you™re interested do send me a PM Many thanks, Quote Link to comment Share on other sites More sharing options...
Chris`I Posted February 4, 2009 Share Posted February 4, 2009 They start off looking like this… And after a few applications they look this…. As long as Nissan dont fit them! Nissan B'stoke somehow managed to fill mine a rusty colour! I can only imagine that they "bedded" them in and then washed it after it had cooled down. Tuning it all rusty Bastwards Quote Link to comment Share on other sites More sharing options...
MITZ@CougarStore Posted February 4, 2009 Author Share Posted February 4, 2009 Hi Chris, do you have the Ultimax fitted to your Zed? Is it surface rust or imbedded into the grooves, never had a set which have rust set in them, only on the surface after a car has been washed and left standing, which clears after a few brake applications… Quote Link to comment Share on other sites More sharing options...
M350ZB Posted February 4, 2009 Share Posted February 4, 2009 As Cs says, pretty udd-normal for them to rust as such, only once washed or leaving the zed to stand for a while, noticed mine yesterday as heading out to work, looks bad, but once driven soon clears quickly . Quote Link to comment Share on other sites More sharing options...
Chris`I Posted February 4, 2009 Share Posted February 4, 2009 Hi Chris, do you have the Ultimax fitted to your Zed? Is it surface rust or imbedded into the grooves, never had a set which have rust set in them, only on the surface after a car has been washed and left standing, which clears after a few brake applications… Not the Ultimax, but the Turbo groved, and the same principal of the coating to stop rust. Should have probably been clearer, its not on the braking surface, but embedded into the grooves. I tried to clean them out with a vigarous wash, but its definately hardened onto the coating They have also got it on the bell (the bit around the hub if thats the right word). You can see where they've washed it as the rust on the bell flows off it like water would have. At some point I will carefully paint the grooves and bell to get rid of it. I get surface rust all the time, this is perfectly normal and doesnt worry me as it comes off after a couple of applications of the brakes Quote Link to comment Share on other sites More sharing options...
xStric9x Posted April 4, 2009 Share Posted April 4, 2009 Well after driving and bedding in these disks along with ferodo ds2500 pads i can confirm the performance is far superior to the oem set up. So if anybody is in need of a change i can defo recommend these Quote Link to comment Share on other sites More sharing options...
M350ZB Posted April 6, 2009 Share Posted April 6, 2009 Well after driving and bedding in these disks along with ferodo ds2500 pads i can confirm the performance is far superior to the oem set up. So if anybody is in need of a change i can defo recommend these At the mo running ds2500 pads on oem discs and noticed the difference then, how much the discs set you back bud ? Quote Link to comment Share on other sites More sharing options...
MITZ@CougarStore Posted April 6, 2009 Author Share Posted April 6, 2009 Well after driving and bedding in these disks along with ferodo ds2500 pads i can confirm the performance is far superior to the oem set up. So if anybody is in need of a change i can defo recommend these At the mo running ds2500 pads on oem discs and noticed the difference then, how much the discs set you back bud ? Mark the first post has the price... Quote Link to comment Share on other sites More sharing options...
M350ZB Posted April 6, 2009 Share Posted April 6, 2009 Well after driving and bedding in these disks along with ferodo ds2500 pads i can confirm the performance is far superior to the oem set up. So if anybody is in need of a change i can defo recommend these At the mo running ds2500 pads on oem discs and noticed the difference then, how much the discs set you back bud ? Mark the first post has the price... sorry bud, internet connection playing up, bits missing on page , Thanks CS Quote Link to comment Share on other sites More sharing options...
MITZ@CougarStore Posted April 6, 2009 Author Share Posted April 6, 2009 Well after driving and bedding in these disks along with ferodo ds2500 pads i can confirm the performance is far superior to the oem set up. So if anybody is in need of a change i can defo recommend these At the mo running ds2500 pads on oem discs and noticed the difference then, how much the discs set you back bud ? Mark the first post has the price... sorry bud, internet connection playing up, bits missing on page , Thanks CS No worries bud... Quote Link to comment Share on other sites More sharing options...
Chris`I Posted April 7, 2009 Share Posted April 7, 2009 Well after driving and bedding in these disks along with ferodo ds2500 pads i can confirm the performance is far superior to the oem set up. So if anybody is in need of a change i can defo recommend these At the mo running ds2500 pads on oem discs and noticed the difference then, how much the discs set you back bud ? TBH unless you are tracking it, then these discs wont give you any advantage over stock as you already have good pads. However, when your current discs wear out, these would be a nice upgrade Quote Link to comment Share on other sites More sharing options...
