Adriank Posted February 3, 2009 Share Posted February 3, 2009 Does anyone know what the std setup is for this, and the tollerance ranges? Think i need to get mine looked at since the Eibach Springs, i have a LOT of Camber and Toe on the rear wheels now. Adjusters are also very expensive it seems, HELP! Quote Link to comment Share on other sites More sharing options...
From A to Zed Posted February 3, 2009 Share Posted February 3, 2009 Hi Adrian, I was given these by Big Phil and kept them in a safe place... I don't know anything about this stuff so I'm just regurgitating the numbers! Camber: Min. -1.33 Deg Norm. -0.58 Deg Max. +0.17 Deg L/R Diff - 0.75 Deg Caster: Min. +7.42 Deg Norm. +8.17 Deg Max. +8.92 Deg L/R Diff - 0.75 Deg King Pin Inclination: Min. +4.33 Deg Norm. +5.08 Deg Max. +5.83 Deg Toe: Min: 0" Norm: 0.04" Max: 0.08" I hope this helps, maybe I'll get a sticky Matt Quote Link to comment Share on other sites More sharing options...
Adriank Posted February 4, 2009 Author Share Posted February 4, 2009 I had seen this posted before, but is this the setup for the front or the rear? Surely the settings wil be different for each end, and that list looks like the full setup info for one of the ends?!? Thanks Adrian Quote Link to comment Share on other sites More sharing options...
ZMANALEX Posted February 4, 2009 Share Posted February 4, 2009 Adriank said: I had seen this posted before, but is this the setup for the front or the rear? Surely the settings wil be different for each end, and that list looks like the full setup info for one of the ends?!? Thanks Adrian Adrian, Send me over your email addy and I will send over all the data that you need mate. Alex. Quote Link to comment Share on other sites More sharing options...
Martin W Posted February 4, 2009 Share Posted February 4, 2009 ZMANALEX said: Adriank said: I had seen this posted before, but is this the setup for the front or the rear? Surely the settings wil be different for each end, and that list looks like the full setup info for one of the ends?!? Thanks Adrian Adrian, Send me over your email addy and I will send over all the data that you need mate. Alex. Wanna sticky that Alex? Quote Link to comment Share on other sites More sharing options...
Daaave Posted February 4, 2009 Share Posted February 4, 2009 When you go to a place to have your geo done they should have all the settings in the machine, but just in case: 350z, 18" wheel (better systems automatically compensate for different wheel sizes by taking measurements when rolling the car back and forth). Rear Axle Camber -1°35' ± 0°30' Toe 0°05' ± 0°02' Total toe 0°09' ± 0°04' Setback 0°00' Geometrical driving axis 0°00' Axle offset 0°00' Front Axle Camber -0°35' ± 0°45' Caster 8°10' ± 0°45' SAI 5°05' ± 0°45' Toe 0°02' ± 0°02' Total toe 0°05' ± 0°05' I've been told by lots of people in the past that it's best to go to a place that uses Hunter alignment systems. They can be found on http://www.alignmycar.co.uk/. Quote Link to comment Share on other sites More sharing options...
