Aust350z Posted February 21, 2010 Share Posted February 21, 2010 I have whitline sways installed. How can I tell if mine would need replacing? Quote Link to comment Share on other sites More sharing options...
ZMANALEX Posted February 21, 2010 Author Share Posted February 21, 2010 Aust350z said: I have whitline sways installed. How can I tell if mine would need replacing? If you run with lowered suspension then you will require the adjustable ARB links to get the knuckles back to the correct angle. Free shipping to Australia Alex. Quote Link to comment Share on other sites More sharing options...
ZMANALEX Posted March 17, 2010 Author Share Posted March 17, 2010 Bump Quote Link to comment Share on other sites More sharing options...
Glenn1981 Posted March 17, 2010 Share Posted March 17, 2010 Just drove down the road and the squeaking is getting too much to bear now. I take it this will fix the problem Alex? How tricky are they to fit for a novice? Quote Link to comment Share on other sites More sharing options...
ZMANALEX Posted March 17, 2010 Author Share Posted March 17, 2010 Glenn1981 said: Just drove down the road and the squeaking is getting too much to bear now. I take it this will fix the problem Alex? How tricky are they to fit for a novice? This will fix your problem as long as the squeak is from the ARB links mate. Very easy to fit and adjust. The only issue that you may have is getting the old ones off but if you are handy with the spanners then there should be no drama. Alex. Quote Link to comment Share on other sites More sharing options...
Glenn1981 Posted March 18, 2010 Share Posted March 18, 2010 ZMANALEX said: Glenn1981 said: Just drove down the road and the squeaking is getting too much to bear now. I take it this will fix the problem Alex? How tricky are they to fit for a novice? This will fix your problem as long as the squeak is from the ARB links mate. Very easy to fit and adjust. The only issue that you may have is getting the old ones off but if you are handy with the spanners then there should be no drama. Alex. Hi Mate, Well the "creaking" as I would more describe it, comes when the rear of the car is on a camber, like turning into my drive or parking on a verge. It is getting a bit too much now so I need it sorted. Quote Link to comment Share on other sites More sharing options...
wizard Posted July 13, 2012 Share Posted July 13, 2012 you still sell these alex? Quote Link to comment Share on other sites More sharing options...
ZMANALEX Posted July 13, 2012 Author Share Posted July 13, 2012 wizard said: you still sell these alex? Plenty in stock Rehan Quote Link to comment Share on other sites More sharing options...
julien Posted August 10, 2012 Share Posted August 10, 2012 Hi guys, A quick (and stupid) question. English not being my mother language... I don't know what the drop links are... Could someone explain roughly? Many thanks! Quote Link to comment Share on other sites More sharing options...
